Lowdown on roller rockers
These things can be easily installed incorrectly/improper.
Pushrod length, wipe pattern, proper lash set up etc all play a vital role.
For the power to be falling of that early with a solid roller is not right.
As I said I had yella terras for 10 years and never had an issue.
I sold those rockers to someone in another state and are still going strong.
The majority of the time issues arise from improper install.
Remember Josh B's engine was running real well at first and making great power.
A spun bearing caused his issues. Not the rockers.
Then he went out and spent all those thousands on other parts.
It will be interesting to see how much he makes with the new all pro setup.
I know. I got one of his packages.
You obviously need to measure for correct pushrod length.
If you get this wrong, your power does fall off earlier if they are too short.
It's out of Tony's hands when the rockers go on as he is not the one putting the rest of the valvetrain together.
It only takes one small error or mismatch to throw everything off.
Just as yella terra have said before too, the majority of issues has been from improper install and setup.
