Cam recommendations from forum members
This thread was for you dude.
Glad to see dbuttsniper on your side. Makes these revelations just that much more satisfying to me.
which one would you be with your **** results?
I haven't recommended anything for a while and then I see this this pop up.
FYI a couple have actually got those specs grinded and were thrilled with the result.
I'm certainly no expert but I have learnt some things about valve events and where they need to be for SOME combinations.
Anything too crazy or with boost etc, I am not confident enough to go there.
Whether I'm right or wrong, it's a learning curve.
Just like that time for a truck camshaft, I was way off.
I admit it. It is what it is.
Secondly I recommend you stop being a troll.
Another member on here was going to PM you to give you a piece of his mind for the remarks you made in a previous thread.
My thought still stands with any stock camshaft.
If you think they are the bees knees of performance I recommend you speak to some professionals.
If you are still not convinced about the benefits of aftermarket camshafts, a psychiatrist should be next on your list of things to do.
People spend too much time on cams. Yes, the tech is fun and good to know but arguing about 5 degrees here or there is lame and for most of us, doesnt matter. Unless you race a 250+ thousand dollar pro mod that you work on under blankets under a big tarp with a full crew that will stab anyone who gets too close.
If running a stock cam is your second kind of cool then by all means go for it. Too far away to race eachother anyways so who cares.
Who's trolling?? Telling you the truth ain't trolling.....unless you don't like the truth.
How are the stock cams garbage bspeck?? They idle smooth, make great power, easy on the valvetrain and get great mpg's. On top of that if you know what you're doing they are plenty capable of easily running 11s, 10s, 9s and even 8s now......all with only bolt ons. Like you i think far to many spends way to much time on cams.....it seems for most the time would be better spent elsewhere.
If guys would spend said time on making the car accelerate instead of fighting a cam they would actually know how good the stock cam is.
Most of what i see with performance cams is trade offs. With alot of these cams the intake manifolds don't work to well with either. How many has been seen with more hp up top but less torque?? Torque is the power a engine makes.
You really need one of my special cam specs.
p.s. im drunk, everything i said could have just been all bs! But i did do muh first burnout in da nova today, lol. Ttyl
Hio has done exceptionally well using a stock cam. It has the right specs for the job he wants done from his engine.
If he were to call Cam Motion and tell them exactly what he wants and under which conditions and circumstances, they could easily spec him a copy of the late LS6 cam.
OR NOT. What he has works for him. If it doesn't work for you, get something else. Thank God for choices...
I would agree also that the party begins in the heads. Better head less cam you need to do same thing. For this conversation - Low and mid lift flow is your friend. Size of port matters etc. Also you need to them match your cam whether stock or modified. No use telling people your heads flow 400 cfm at .900 lift when your cam is .550 lift and the heads have not so great flow up to .500 but they come alive after that. I am not spouting anything new here just mentioning it. Like people said above its a combination of parts. Furthermore, the rest of the car makes a difference too with gearing, converter, weight exhaust etc.
Anyway got sidetracked - I think it all boils down to what are you doing with the car as it relates to a cam, heads and the rest of the package.
I may never track it. Seems every track around here wants more safety stuff than I'm willing to fool with. Doesn't mean I can't enjoy it without a time slip.
If you go on street car races it seem tracks are a bit more lenient. I don't have any of the safety stuff that is required in either of my cars because they are just street cars in the truest form. I don't intend on making them nhra legal either.
Someday i would like to do a c4 vette into a drag car .....with a stick of course. They could be made to weigh in the 2400lb area pretty easily as a pretty hard core strip/street car. Would likely run faster than 9.5 with a junk stock cammed ls7.
It's not that i think cams are terrible bad. It's that the stock stuff is pretty damn good and developing the car seems to be of more benefit to most vs shoving a cam in and fighting tunes, valvesprings and lower dcr's......especially for street car stuff.
Maybe developing the car isn't as cool to some. But it sure works. I went from 12.2@118~ with the initial install of the ls6
to 10.7@130~ utilizing the same stock cam......and i would bet the car had 10.4 in there at last before i eff'd up.
We got lazerlemon ls3 c6 to go from a initial run of 12.6 on a not great day at the track to 10.5@132 with the same stock ls3 cam.
We already discussed sxc car and how well it does. So unless you cars are accelerating at least somewhere near those examples.......you're problem ain't the cam no matter how much you think it sucks.
There's been plenty of guys on ls1tech with strokers, full built motors that don't even get to that.....the cam ain't their problem either......neither are the heads.
In all honesty i think you could get a 346 with a ls6 cam to somewhere near 500whp. We made 451whp 423wtq with bolt ons on my ls6 on pump gas. Now add these super fuels and it would pick up 20whp or so over pump. You're looking at 470~ whp. Clean the heads up, put a thinner gasket on them and mill the another .050. That would put one right in the 490 range just with basic hotrodding.......stupid junk stock cam.
204/218, 117.5 LSA? W I I I D E split, HUGE LSA, which normally go against "common" cam logic.
BUT it works, at least for Hio. Who are we to argue??
And here am I with an 04 Tahoe with LM7, in which I may someday stick a BTR Torque cam (202/202, .511/.511, 111+1) because I RARELY get above 5k RPM.
Because that is what will gain 20# torque throughout the range, and WILL work for ME.
Main point here, we use what WORKS for US. You use what works for you.
G atsma hat torque cam actually looks decent from richard holdener tests. Puts power where a truck needs it. Idk about the tune in your Hoe but the tune in my 2500hd 6.0 was neutered especially in 1st gear. It had a pe delay of 60 secs or until 5200 rpm. So basically even if you were wot in 1st gear you weren't really wot. I turned that off and the truck picked up 3-4 tenths via draggy on that change alone. You might want to check your Hoe tune fo dat.
G Atsma that torque cam actually looks decent from Richard Holdener tests. Puts power where a truck needs it. Idk about the tune in your Hoe but the tune in my 2500hd 6.0 was neutered especially in 1st gear. It had a pe delay of 60 secs or until 5200 rpm. So basically even if you were wot in 1st gear you weren't really wot. I turned that off and the truck picked up 3-4 tenths via draggy on that change alone. You might want to check your Hoe tune fo dat.
I'll look into the tune when I can. Gotta find someone who knows their $hit about tuning around here. Call out to anyone knowing good tuners in Central Kommifornia!
Deleted the AC too so that takes drag off the crank and lightens the car.This thread is for cam advice from forum members right? What would you change Bort? 242/250 114+3 .612/.613 lift. It’s not my first choice either but I bought it for $125 years ago and it is free to me now :p
old cam 226/242 on 117+3.5
Stroked ls2 4.005x4” with stock ls3 heads (shameeee!), rod mod ls3 intake, 11.1:1 compression, 1 7/8” headers. 2800 pounds, 3.90 gears.
