Cam recommendations from forum members
204/218, 117.5 LSA? W I I I D E split, HUGE LSA, which normally go against "common" cam logic.
BUT it works, at least for Hio. Who are we to argue??
And here am I with an 04 Tahoe with LM7, in which I may someday stick a BTR Torque cam (202/202, .511/.511, 111+1) because I RARELY get above 5k RPM.
Because that is what will gain 20# torque throughout the range, and WILL work for ME.
Main point here, we use what WORKS for US. You use what works for you.
In the early days, "The Pepper 🌶" was the first truly optimized bolt on car I recall reading about on LS1Tech.
Raughhammer had a1998 cayenne red Z28. named "The Pepper 🌶" showed what a well planned bolt on car could do by ETing ~ 11.5 or 11.6 in the quarter mile.
No fancy high dollar bolt on's like 1.9 roller rockers on a crate LS6 engine - just a bolt on LS1 with a LS6 intake etc, killer set up and great driving.
In 2002/2003 Raughhammer did a MTI heads & C1 222/222 Hammer cam - package and "The Pepper 🌶" ran high to mid 10's with various tweaks. IIRC Raughhammer hit like 10.4x in the "The Pepper 🌶" with a bigger MTI X1 cam 230/227.
I think its safe say Raughhammer like HioSSilver believed it was best to ream ALL of the 1/4 mile ET performance out of a bolt on car and get the fully car dialed in before stepping up to cam/heads & cam etc.
Of course for the casual hot rodder like me reaming the last 1/10th. In 1/4 out really doesn't matter all that much. Having a fun daily driver is more important.
I did try some speed master 1.9s after i $hifted. No results on those.
You will for sure learn more about making the car accelerate with bolt ons vs cramming the largest cam you can find in it. Even the lowly ls1 is capable of running well into the 11s.....and it's pretty easy to do. If one can't get a engine well known to make it to the 11s then they aren't ready for a cam.
Nothing will dd better than the stock cams.
It changed the sound of the engine quite a bit. A lot different induction noise. Sounds badass. I didn’t expect a bigger cam to take less idle airflow and have better throttle response but the thing is happy.
https://youtu.be/BHNtAkRp9Zc
Sort fits in with that stock cam is awesome sauce theme you likes to push
