Torrington bearing ?
This is my first bowetie block and I was wondering if anyone knew if there was some kind of torrington bearing or thrust bearing or washer that went in the rear of the block. On the rear cover, I can see a wear pattern inside the cover, but do not know if there was something there for thrust purposes. I have the 2 little rubber pipe gaskets, but unsure if I need something else. Any help would be appreciated. Thanks
Nothing between cam and back cover
