LS3 Corvette pan and drag racing
Old Oct 6, 2020 | 12:44 PM
RonSSNova's Avatar
Default LS3 Corvette pan and drag racing
Only a handful of passes on
my new 6.2 in my C5.
i used the LS3 Corvette pan instead of the orig LS1 batwing pan. It’s just so much easier to deal with for clearance etc.
Reviewing logs, I see the oil pressure drop to 30 psi in low gear. Then comes back to normal. It’s 60 at the finish line.
Cruises at 50psi on the freeway.
36-40 at hot idle.
The drop on the launch bothers me.
Seems this should be an issue on any C6 LS3 car, but could find no info. Maybe nobody looks or logs it.
I’ll try adding a quart. It only holds 5.5 stock fill.
And yes I know about the Improved Racing setup. Big $$$ and it’s not trivial at all to replace the pan on a C5 with the engine in the car.
Just wondering if anyone else using this pan has noted this.
Ron
Old Oct 6, 2020 | 12:48 PM
I bet it just barely starves on launch in first, then recovers the rest of the run.
Adding a quart should help or even eliminate the issue, hopefully.
Old Oct 6, 2020 | 03:19 PM
RonSSNova's Avatar
I’ll try that. Already added.
Old Oct 6, 2020 | 03:38 PM
Keep us posted...
Old Oct 6, 2020 | 04:35 PM
RonSSNova's Avatar
I wondered when I looked at that pan.
Pickup in the middle, not near the rear.
Baffles did not look like they would hold oil near the pickup on a hard launch.
Just figured GM knew what they were doing......Ha
Here in Orygun, the weather will change and rain till June.
Nice tomorrow though. 1/8 mile, might be some prep, maybe, if I plead with them.
I’d like to take the Nova. 1/8 mile bracket race. Hmmmm
Old Oct 6, 2020 | 04:58 PM
I have relatives in Mt Angel/Silverton. I always enjoy driving thru Oregon... even when raining, which seems like most of the time... lol
Old Oct 6, 2020 | 05:30 PM
DavidBoren's Avatar
Yessir, it rains 300+ days of the year here in Oregon... not worth ever coming here... should probably just stay wherever you are, or at least not here.
Old Oct 6, 2020 | 07:29 PM
SLOW SEDAN's Avatar
I run an LS3 pan and your oil pressure all around seems a little low, mine is 60-65 cold, 50-53 warm idle, and 80-83psi or so full send but I run 6qt’s and a leftover G8 oil pump.
Its fairly easy to hold engine up and drop subframe to get to pan, I drop subframe down and engine is out in 1.5 hours taking a break for beer. Its great not having to pull the trans throw a jackstand under the torque tube and rock on.
Old Oct 6, 2020 | 08:13 PM
RonSSNova's Avatar
Melling M295. So stock.
G8 pump I know nothing about.
Im tired of working on it! I’m an old ****!
Ha!
Old Oct 6, 2020 | 10:09 PM
showdog75's Avatar
My tuner described the exact issue you have. He added a extra quart.
Old Oct 6, 2020 | 10:47 PM
RonSSNova's Avatar
Just a slight bit easier than replacing the pan.
Thanks.
I’ll report back
Old Oct 7, 2020 | 07:18 AM
SLOW SEDAN's Avatar
Ha!
Its just an OEM high volume pump, so maybe moves a bit more than the M295 standard volume.
Old Oct 7, 2020 | 09:24 AM
RonSSNova's Avatar
👍 Got ya. Will give a bit more pressure.
Old Oct 8, 2020 | 09:20 AM
joyridin''s Avatar
Those pressures are exactly what I see in my LS3 with a HP Mellings pump. When it was machined, we did open the rods up a bit with a .001" OS upper rod bearing. I do not run a factory gauge and it is plumbed at the top of the engine where the factory sending unit was originally located. My mechanical gauge gets a bit higher pressure.
Old Oct 26, 2020 | 09:28 AM
grinder11's Avatar
36-40 at hot idle.
Ron
Hi Ron. It'll be interesting to see if you lose any power. I've found that running a quart low on my C5 batwing (6.5 qts full), I pick up a couple mph in trap speed. More room for air to pump without losing power to pumping losses.....
Old Oct 26, 2020 | 10:44 AM
RonSSNova's Avatar
I added the extra quart. It helped. Pressure just drops to 45. But then the track was slicker, so less G’s at launch.
Anyway, it ran its best mph, so no detectable loss of power.
I asked questions on the C6 forum. I gather no one pays attention or logs oil pressure when drag racing C6 vettes.
Or my problem is unique.....
Old Oct 26, 2020 | 03:12 PM
RonSSNova's Avatar
I’ll figure this out myself.
Ron
Old Oct 27, 2020 | 01:07 PM
DualQuadDave's Avatar
There has to be more info on this. Too many Vette's launching hard for there not to be. You may message some hard hitters directly, you'll get a better faster answer
Old Oct 27, 2020 | 02:20 PM
SLOW SEDAN's Avatar
As a note on oil level I poured 5.5 qts in my pan and noted the level for a turbo drain location, the oil level was still down a good 1.5" from the lip of the pan, so you can easily run more oil and not be anywhere near the windage area. I think you can run 7qts and be fine as the oil level will be lower when running as well.
Old Oct 27, 2020 | 02:43 PM
wretched73's Avatar
I forget the exact thread on the corvette forum, but a member there went from his stock c6 wet sump system to a dry sump system. He did that because he was drag racing frequently and spun a crank bearing multiple times. After switching to the dry sump system he didn't have that issue again.
This is only one example and I can't find the thread but it is there if you look for it.
