415 more cam?
Old Oct 8, 2020 | 07:45 PM
kirk tarrant's Avatar
Default 415 more cam?
Running a 415 ls3 with CNC ls9 head's.
currently my best 1/8 is 6.46 at 104 with 1.325 60.
Going with fast Hiram this winter.(not Holley)
Car has a 236/250 .625/.625 115+4 cam.
Is a cam change worth the money and time?
Any recommendations?
Car is c5 rpm level x 4l65 3.73 fti hard hit 4000
Old Oct 8, 2020 | 09:54 PM
64post's Avatar
1.25 60ft? Doesn’t seem like it needs a bigger cam. What will I that run in 1/4 mile? What intake are you running now? How much do you think the new Fast intake will add?
Old Oct 8, 2020 | 10:32 PM
SLP IROC-Z's Avatar
1.25 60 and 6.4s? Timing error?
Old Oct 8, 2020 | 10:33 PM
SLP IROC-Z's Avatar
around a 10.0 1/4
Old Oct 8, 2020 | 11:11 PM
spanks13's Avatar
That sixty foot is 2 tenths faster than it should be for that ET lol. Are you a wizard?
Also yes, a bigger cam for a 415 would be good - especially with a bigger intake that would support a lot more revs.
Old Oct 9, 2020 | 05:43 AM
Tuskyz28's Avatar
The way the car is performing now I'd hate to swap the camshafts. I've seen guys go to a bigger cam and slow their car down.
Old Oct 9, 2020 | 05:46 AM
bortous's Avatar
I would use something like cam motions 244/256 113lsa+4 if you want something more aggressive.
Old Oct 9, 2020 | 07:51 AM
Darth_V8r's Avatar
Moderator
What is the rest of the build details? Looks like either a nitrous or Procharger cam. What compression you running? What are your shift points?
Old Oct 9, 2020 | 07:47 PM
Error on 60 foot. Sorry 1.325. it's a na car
Currently shifting at 6750.
About 11.5 compression....
​​​​​​ leaving at about 1000 rpm. Spins any over that.
im very happy with the car. Was junk yard high mile 6.2 block with no machine work and cheap skat stroker kit.
Hand me down heads from another build and used cam.
