cam question 0967
Hi
I have a 5.3 engine that I am going to swap into an older car and I want to delete the DOD.
Will a "0967" 4.8/5.3 190/191 .457/.466 114 lsa cam work in a 2014 5.3 DOD engine?
this is not going to be a race car and I have seen some engines have different cam journal sizes
thanks
thanks
Yes it will. Does the 2014 engine also have VVT?
Cam journals are the same. Block cam bearing bores can be different. Get the right bearings for the block
