LS3 with LS7 Drysump, something to do?
Thanks for any help. I heard about there is something to change (closing of ports?) on the LS3 block oil system, if an LS7 dry sump is mounted.
Regards
I already have the LS7 dry sump mounted on my LS3 engine. So the most you write must have been installed.
But I heard that something has to be changed on the LS3 block, otherwise some parts do not get enough oil ??
What I figure out on blue prints is that both work on the same port of the block. So I do not see any difference. What about the way around the oil filter?
to realy understand that, with internal ls7 dry sump pump, there is nothing that needs to be changed inside the ls3 block !?
do you know any pics oder partlists that I could doublecheck that everything is correct and mounted inside?
is it possible to see the crank is the long nose one installed with demounted oil pan?
THX !!!
