3.9 stroker piston options
Old Nov 12, 2020 | 11:48 PM
sakers288's Avatar
Default 3.9 stroker piston options
Does anyone know of any manufacturers with off the shelf pistons for a 3.9 stroker 6.0 other than DSS? I see wiseco does but the two options they offered were either a ~12.5:1 ratio or a 9:1. I was looking for something in between like a 10.5:1 ratio w out special ordering pistons.
Old Nov 16, 2020 | 12:32 PM
DavidBoren's Avatar
Depends what rods you plan on using...
Assuming you are going to capitalize on the shorter stroke with a longer rod... Summit's 1.110CH pistons should work with a 6.2" rod and a 3.9" stroke.
That's just a really quick search waiting for a model to load at work. I can look more in depth if you tell me which rods you plan on using.
