6.0 Cam Advice to suit 8 stack
Hoping I can get some advice on a cam selection for a bit of a weird combination.
I have a 6.0 LS that is virtually stock, other than an 8 stack manifold and big exhaust. Running a Tremec 6060 and 3.45 rear end. Weight is about 2200 pounds.
I am looking for good street performance rather than max Hp, but obviously I a want to make use of the huge airflow potential of my intake and exhaust. Heads are stock but will probably get them ported at a later stage.
Any advice on cam specs for this type of configuration would be a great help!
Thanks. Ben
I would call a cam grinder (Cam Motion, TSP, Brian Tooley, etc.) for advice, as IR manifolds have different dynamics than plenum types.
With Webers on your engine, you could run whatever cam you wanted and it would idle nice, and make great power and induction noises. They are designed for *function* in an IR configuration, where IR EFI setups are mostly looks ... they don't run well on the street without a TON of work. JMHO.
Any lack of smoothness in the way your engine runs will be multiplied 3x by the fact that your car is so light. I have some experience with this problem. :-)
Thanks. Ben
I would not recommend porting the LS3 heads. The sacrifices in airspeed can offset the flow gains. I've been associated with a few cars that did better on stock LS3 heads than on ported LS3 heads. Maybe do a really good valve job and bowl blend on them, which would be most of the gains you'd see from a port job anyway. If anything, i'd rough the runners up some.
As to cam, I think I'd go along the lines of 232/240-110+2. Possibly would need to flycut if the cam is large enough.
Like 68Formula said, a lot depends on the ability of your management system. You'll need Alpha-N. Personally I like blended Alpha-N and SD.
