What limits RPM?
Comp Cams recommends this spring kit, 26926TS-kit spring kit. Have to see what's in there when I pull the valve covers.
I will up the boost but not before forging the rotating assembly.
I've ridden 7600 RPM for 15+ seconds on high boost with stock: rockers/trunions/pushrods/valves/retainers/lifters/timing chain/pistons/rods/rod bolts.... basically everything stock except cam/springs.
Your gen 4 bottom end is stronger than my gen 3 bottom end. Don't stress too much over upgrading things that don't need it.
Are you looking for a power goal, or do you just want to turn rpm regardless?
I was looking for something else and ran across this;
"ULTRALITE
Yella Terra’s exclusive Ultralite rocker arm, shaft and pedestal system offers 50% less nose weight than the factory rocker system, the result being greater RPM potential without compromising strength or durability. The perfect low-maintenance substitute for factory rocker arms which utilise problematic cage-less bearings, solid non-roller tips and heavy steel bodies. Yella Terra Ultralite is ideal for high revving street applications when coupled with factory/lightweight aftermarket springs."
According to Yella Terra their Ultralite rockers have 50% LESS nose weight.
"ULTRALITE
Probably need some dual valve springs and better rod bolts to spin to 8K safely. Not sure if the stock intake can support that, though. Might want forged rods/pistons, but I don't know if they are absolutely necessary.
