Need more lift
I'm considering adding 1.8 ratio rockers of some sort. That will bring valve lift to .656. I have a couple of questions:
The heads are milled .010 and installed with .040 Cometic MLS head gaskets. Am I OK PTV wise?
Is this worth doing? I think it's time to change the valve springs and don't have a whole lot of confidence in the stock rocker arms either. Hopefully I'll get a little bump in power. Anyone hazard to guess what that power bump might be...
If I did this, what would your valve spring of choice be? The BTR"s I have now are rated to .660. Valve lift with proposed 1.8 ratio rockers is .656. I'm somewhat allergic to Comp Cams and Tx Speed valve springs as I've had failures with both and little to no factory support from either.
Help appreciated.
Your intake valve is opening (.050") a degree and a half before mine does, 2 BTDC rather than .5 BTDC. ... so that will steal a little clearance.
Given the clearances I measured, I let the engine warm up before I beat on it. I haven't had any issues.
What I'm getting at here is, I think it may be very close. I think the big unknown is what the difference in our heads does to the clearance. If it was me, I'd put some test springs in it and measure the clearance with a dial indicator on the end of the valve. I think you are close enough to having an issue that a measurement is the only way to really know. You could even measure with the rockers you've got in it now, and then adjust for the additional lift (and reduced clearance) that the 1.8 rockers would give.
With 1.8 rockers you may need a valve cover spacers. But PTV clearance is pretty much a non-issue. Anyway, PTV issues is WAY MORE related to cam duration specs than to cam lift or heads mill...
I ran Comp Cams Ultra Pro-Magnums with Texas Speed ported heads and Lingenfelter cam LS3 for a while...... 229*/242*, 114* + 0*, .668"/.668' lift and .040" Cometic head gaskets....no PTV issues at all.
KW
And I guess I'd wonder what does "no PTV issues" mean? I haven't had any either, but I'm running .060" on the intake side for clearance. Did you measure yours?
YT rockers because it's a Mamo spec'd top end. I had to use thicker valve cover gaskets to clear the rockers.
