L96 questions
It's not watered down, e85 just has less BTU's than regular gasoline but a much higher octane, you burn more of it versus gasoline, so your fuel consumption will go up but if your engine is tuned for it, your power can go way up too. The octane rating of e85 is around 108, so higher compression, more timing, or obviously more boost, is where it really shines. Although a lot of e-85 out of a pump is nowhere near 85%, usually much lower.
