Stroker build questions
I 100% will be turboing the car in the next year, but I think I'm going to run N/A until then (the car has been down for a year I want to drive it soon).
I guess my questions is should I switch from my ported 243 heads/ls2 intake to LS3 heads/intake or just switch intakes or does it even matter if I'm turboing.
Second, I know i'm going to need another cam. Any suggestions for a stroker turbo cam?
This is 100% not a daily driver and will be on e85.
I'd stick with everything you currently have, cam included, and get an 80 to 88mm Borg warner clone in a 96mm turbine with a 1.32 A/R T6.
That cam is smaller than the one I'm putting in my turbo 5.3.
2. Get with Cam Motion regarding a turbo-cam to fit YOUR needs and your engine.
KW
