Valvespring distance from bind
Like...is that .060" from bind cold with a checking spring, or .060" from bind with .014" hot lash and probably .010-020" of deflection - IE more like .045" from bind when cold with an actual valvespring in there.
My cam is .775" gross lift and I'll be spinning the engine 8000-ish. Should run in the range of .014 hot lash. It is really making it tough for valve spring selection and this last little bit of installed height is making a difference when shopping around. The 1209x is probably not enough, and the 1238x I'm worried about for a number of reasons.
PAC - 1209x - Comp thinks these will probably only be good to 7500rpm with my cam and valvetrain
Seat pressure at 1.800 - 160 pounds
Open pressure at 1.050 - 535 pounds
Spring rate - 515 lb/in
Coilbind 1.000"
PAC 1238x - I bought these already. Comp thinks they're good for 8500rpm or more with my setup. I'm concerned with spring life, broken springs, and my biggest concern is ripping the top of the intake port out with the ls7 pedestal mount rockers. Probably really ought to be using a shaft rocker. I've read about guys being successful with this setup drag racing, but ruining a cylinder head is not my goal. I also have no interest in machining these heads for shaft rockers.
Seat pressure at 1.800 - 250 pounds
Open pressure at 1.050 - 700 pounds
spring rate - 600
Coilbind - .985
Manley Nextek - an interesting choice that may work slightly better than the PAC 1209X? When shimmed up, same open pressure as the 1209x but a bunch more seat pressure.
1.800 installed height - 165 pounds
1.000 open height - 515 pounds
spring rate 435 pounds/in
coilbind - .900"
If shimmed up to 1.700 - 208 pounds
.950 open - 535 pounds
Lastly - Comp recommended these PAC circle track springs as a tweener option, but these are astronomically expensive and I can't justify it. $700 for springs only - still need seats retainers etc all bought separately. I'm trying to use this as a reference to get as close to these performance specs as possible without spending nearly a grand on springs.
PAC 1529
1.900 installed height - 180 pounds
1.150 open - 600 pounds
rate 560 pounds
coilbind 1.085
Installed height 1.850" - 173 on the seat
1.100" max lift - 585 pounds open
spring rate 585 lb/inch
coilbind - 1.045"
This gets very close to the expensive PAC1529 recommended by Comp.
Still curious about distance to coilbind lol
coilbind - 1.045"
Valves are Ti 2.200 intake and stainless 1.59 exhaust - 77g and 101g exhaust. I'm using the T&D LS7 pedestal mount rocker arms.
I want to set my limiter to 8200 and try never to hit it - maximum revs likely 7800-8000 but will be decided by the powerband.
My concern with the 1238x is running them on the ported stock ls7 casting and either pulling the threads out or breaking the top of the intake port since I'm using the pedestal mount rockers and not shaft rockers.
PAC 1529
rate 560 pounds
coilbind 1.085
when purchased 🤔. Main❓I asked: 😉 This is intended for 98% street use.
Perfect choice for the lift and spring rate.
If considered your cam lift is what? That's before Lash Subtract'$ from what's: said / advertised 🤔. Does the 1237x fit the bill? 👉💸💵
👎PAC-1237X RPM Series RACE ONLY Dual Spring Open Load 585👈
Recommended Valve Lift 0.700👎
Spring Rate (lbs/in)550👈
👍PAC: 1238X RPM Series RACE ONLY Dual
Spring Open Load 700👈
Recommended Valve Lift0.750👍
Spring Rate (lbs/in)600👈
Same price around $25 ea.
With LS7 valves you can set up taller installed height 1.960" is stock. 1237x at 1.850" installed height makes room for .750 lift and lightens up on the spring pressure a little.
Which lobes are you running? The low shock from comp I selected are also 774 gross lift with a 1.8 rocker, .430 lobe lift. .756"/.420 exhaust lobe lift.
The extra lift ought to be a significant performance bump. I'm excited to see what it does. For the RPM range 5000-8000 I don't think you can utilize much more duration than a 258 intake lobe, so more lift makes sense to me to get more out of it. I also want a fighting chance of driving it on the street and 33 degrees overlap hot is already pretty rowdy even for a 429.
