Valvespring distance from bind
With LS7 valves you can set up taller installed height 1.960" is stock. 1237x at 1.850" installed height makes room for .750 lift and lightens up on the spring pressure a little.
🤔 Reasons for asking the 1st Statement. Kills Any ?
A hydraulic Spring Pressure is Different than what a S/R may be asking? Reason for the ❓
On the Studs you maybe able to do the ER taught Trick....Swap Truions >Tap for bigger studs Move on. Comp cams LS rocker Truions will Swapp for Comp cam BBC 7/16 Truion. If T&D sells other Stud Mounted rockers they May Swapp.
Valve Springs breaks Rarely but, if You've got Good Lifters it's Best to Have More Control of the valve than 🚫🤔
Just seen your post 👆 Always caution on the Safe side and if the manufacturer Has seen both Springs go with there Recommendation 👍😉
