So should i Stroke it?
#42
OP needs to street drive a 4" stroke LS2 in CA, so wants 0 overlap or something that will pass a sniffer. What cam?
#43
Wow that's A deep question but it's Really not..🤔
Burn the gas ⛽ Early?
I'm Betting the Farm ......👍
#44
Complete burn = matching the Compression?
With the amount of Duration so As to have a good Cranking compression While not 🚭 allowing BS excessive Gas blow Bye to Reach the Catalytic converter aka 02 sensor? 91 octane in Cali 🤔
Idk🤣😂 never did get camming 😭🤣😂🙂 Call it in 2 Steven/Bobby @ Cam Motion > or PM 👍 Darth 4 a mini 🐴 = Donkey D cam. Main thing is your octane Regulation @ 91 and compression 🤫
Bortous Where U @........Early burn camming needed 🙂
#45
Most off the shelf cams seem to want overlap. If i wasn't in cali they would probably work fine but decided to do what some of you said and have one of the pro's spec out a cam and see what they recommend.
#46
After wallowing in my regret and shame for selling my camaro for the last 3 years. I got an 07 vette M6 and because i can never leave well enough alone decided i wanted more but since road side smogs like to pop up randomly in my area still needed to pass smog so just got myself a Fast 102, ported 799 heads, and a TSP 224R 112 LSA. My buddy started tearing down the car for me and immediately we saw the previous owner was an ahole and put a bunch of unknown crap on the snout of the crank to get it by to offload it. After getting it off it looks like he must have drove it around with a wobble before that because its ruined. So now i am saying screw it lets pull it out and see how much power we can get out of it and pass the sniffer. With such a small cam necessary to pass smog is it even worth stroking it?
Specs: 244*-248*-112*-.631"-.631". Put down 530+ho and 510+ tq on a mustang dyno
#47
226/232 118+4 LSA even less overlap then the recommendation i got from everyone. I was thinking something around 0 also but -7 it is.
#49
Because not everyone knows what they are talking about. That cam sounds perfect for your situation. Pair it with a decent exhaust for a sleeper.
The following users liked this post:
G Atsma (12-22-2020)
#50
Yeah looking at the specs it definitely sounds exactly like what i wanted. I was looking at the ghost cam or tsp 228/232 on 115 lsa which looked like as close as i could get off the shelf. Glad some of the guys here put it in my head to go custom.
#51
LSA is 118 ... +0? +1? +2?
That should be a super smooth, nice cam to drive on the street.
#52
I got no recommendations, just got a question. Which is the real problem that needs to be addressed with a stroker?
1. Stroker needs a longer duration cam
2. Stroker needs more air
Seems like some people are actually arguing like (1) is the fundamental issue, instead of (2).
I was under the impression a longer cam is a crutch for heads that don't give the larger engine the air it needs in the same degrees of rotation as it did with the smaller engine. Put the right heads on the stroker and cam duration gets shorter to do the same job. In other words, when building a stroker the smart money goes in the heads, right?
#54
And I've got another question for you guys that have spent a lot of time trying to understand cam selection.
What exactly are you focusing on when choosing IVC event? Seems like people often come up with answers down to the gnats *** and I'm curious how you arrive at those numbers. I've never dug into cam theory but I'm starting to get more curious about it. Are you applying some kind of rule of thumb for where in the crank movement you get optimal cylinder fill? And then anything beyond that number is just fine tuning DCR? (I suppose ideally you would fine tune DCR with piston and avoid pushing air back out of the cylinder.)
Same with exhaust duration, how do you guys come up with those numbers? And what rule of thumb are you using for how exhaust overlap effects IVC event?
#55
OP specified ported 799 cathedral heads which in my mind turns your point #2 into point 1.
IVC is a balance between managing cylinder pressure, high rpm breathing, and reversion at low rpm. Generally the later the IVC the higher you can rev it and the more power you make at higher rpm ranges, the worse low rpm efficiency and performance, and less dynamic compression
#56
Yes, but how are people coming up with specific numbers? Do they actually know how to do it from scratch, or do they just have a reference catalog of what they've seen work?
I see threads where somebody says IVC should be xx°, and then somebody else will come in and say, no, it should be (xx+1)°, and the first guys says, yeah, that would be better. How the hell are they able to decide down to that level of detail?
#58
I think the slightly earlier IVC of this cam is done to help with driveability (and maybe emissions) at lower rpm and load. Or since it's a street car, the OP may have told the cam guru that he'd trade top end horsepower for manners and midrange/low end. Earlier IVC even than this would start to cause the dynamic compression to be too high given the 11.x static compression that will probably be where this engine winds up.
The +4 advance on the cam got us to 47 IVC from the 51 that it would have been with zero advance. It also ensured that during the overlap period, the intake valve is open a lot further than the exhaust (EVC 6 BTDC, IVO 1 ATDC). Not sure if this is intentional for pseudo-EGR, or what... but for sure you're going to be sending less unburned intake charge down the exhaust pipe.
