Who makes Jegs 20825 lifters?
Old 01-25-2021, 05:54 AM
Stampede4ever's Avatar
Where to buy true LS7 Lifters at?
Thanks.
Old 01-25-2021, 09:02 AM
Jimbo1367's Avatar
Originally Posted by Floorman279
Not why i said that, it was meant that now it forces ppl to run a better lifter
ooh, that makes total sense. That prolly why I didn’t get it . LOL
Old 01-25-2021, 09:10 AM
SLOW SEDAN's Avatar
The only problem with that is for everyone like you who has had good luck, there are probably quite a few who haven't been so lucky, and their $10,000-$15,000 engine was brought down by a set of $100 lifters. 16 lifters costing $100 would make each lifter only $6.25!!! A pretty complicated piece of hydraulic (or solid) equipment for a mighty small amount of $$. That's retail!! Wholesale is probably $3 something each, and the manufacturer has to make a profit, so your trusting your $12,000+ engine to a $1.50-$2.00 part. What amount was left for the neelde bearings, the roller, heat treatment, R&D, if any, etc., etc. I'm glad you've had good luck. But I'd never trust an high performance engine with those kind of parts. Maybe not even a low performance engine. To each his own. But to me, using a $100 set of lifters in an expensive engine is like playing Russian roulette; You hope like Hell you get the luck of the draw.....
I've never had a $10k or 15k engine, but if I did then yes I would get better lifters. Luckily 1200hp only takes a $2000 engine
Originally Posted by Sacrilege
A $700 set of lifters doesn’t necessarily mean quality or a proper amount of R&D either.
Exactly, I've had $500+ lifters fail too many times.
The following 2 users liked this post by SLOW SEDAN:
DualQuadDave (01-26-2021), G Atsma (01-25-2021)
Old 01-25-2021, 09:17 AM
ddnspider's Avatar
Received 1,747 Likes on 1,304 Posts
Amen to this. I've seen WAY to may high $ NA motor failures lately and some of them have been valvetrain related.
The following users liked this post:
Quick Reply: Who makes Jegs 20825 lifters?
