What cc head do I need?
Old Feb 25, 2021 | 09:50 AM
Utinator's Avatar
If you are using their block, then I would use what they recommend. I was assuming that you just had a GM block re-sleeved.
I was also wondering about the coolant jackets. I don't see how the big bore sleeves stay cool. They cut into the coolant jackets in the block. The block and heads normally line up. With bigger sleeves, the coolant passages won't be the same. I'm sure Dart figured out how to make it work on their block though. Do you have any pics of your block?
Old Feb 25, 2021 | 11:51 AM
AINT SKEERED's Avatar
Originally Posted by Gripenfelter
So I’m going to be using a DART NEXT LS 427 block.
I spoke with DART and they were adamant about using gaskets made for their block only. They said the cooling holes won’t line up otherwise and I’ll have issues if I use LS7 or any other gasket. Weird.
Didn’t make sense if I’m using LS heads. I’m using Trick Flow 245 cc heads.
So the only gasket I can use is a Felpro 0.051 gasket.
I'm using cometic 6 bolt head gaskets on my dart block. No issues at all.
cagc 5703-40
cagc5702-40
Old Feb 25, 2021 | 01:22 PM
Gripenfelter's Avatar
cagc 5703-40
cagc5702-40
Thanks for the part numbers.
Old Feb 25, 2021 | 08:49 PM
you dont have to but I sprayed copper coat on mine
Old May 4, 2021 | 08:47 PM
So I ended up with 11.61:1 compression. DART 427. But is my math off or is my Dynamic compression at 9.94? http://www.wallaceracing.com/dynamic-cr.php
I used a different calculator and got 8.9.
https://www.gofastmath.com/Compressi...tio_Calculator
See attached pics.
Old May 4, 2021 | 09:00 PM
Darth_V8r's Avatar
Moderator
Dynamic compression is based on 006 valve events not 050
Old May 5, 2021 | 07:22 AM
For your dome volume, you entered zero. What piston are you running? Agreed with Darth on dynamic numbers calculation.
Old May 5, 2021 | 07:23 AM
I have 8cc pistons.
Old May 5, 2021 | 07:26 AM
I have 8cc pistons.
That will make a difference. Enter +8 in the spot there.
