What cc head do I need?
I was told with a 68cc head and 0.053 thick gasket it would be 11.1:1 compression.
So checking my math, if I go with a 64 cc head would my compression be about 11.57:1 compression?
I have 8cc valve reliefs with a 60cc chamber, .040 gaskets and my pistons come up .003 above deck and im at 12.49 compression.
Cam is a 244/256 .629"/.604" 114+3
Heads are TFS 245cc.
The cam would be fine at 11.5
Go thinner on hg will help be more kr resistant.
I'd run boostane anyway so you not limited by the fuel.
In an ideal world, the piston will just barely kiss the cylinder head deck, forcing ALL the mixture into the chamber. However, this is not realistic, for obvious reasons. And there is rod stretch with rpm. I figure between .025-.030 at 8K rpm, so set the quench just a bit higher than that for clearance. This allows for slight variation in piston deck heights. This is where the commonly accepted .036" ideal quench value is derived from.
What this does is force almost all the mixture into the chamber, so it all burns when it should, leaving no further fuel in the cylinder to detonate in a secondary burn event OR to burn early due to hot spots in the gap between the head and block. So even though compression is raised 0.2-0.3, the chance for a KR event is actually reduced.
Running a thicker head gasket allows more of the mixture to bleed into the notch between the block deck and head deck, which increases likelihood of an incorrectly timed burn or residual fuel in the chamber that then burns a second time. So even though with a thicker gasket, compression is reduced, the chances of KR are actually increased.
Only issue I was ever aware of with cometic was on gen 3 engines with that stupid notch in the deck of the heads - 241 and 853 particularly
It might not be the best calculator, but it will get you close. It doesn't have the piston to cylinder wall volume, or the head gasket bore/volume. I think it calculates everything else that you need though.
Here's another thought...if you get a head gasket with the same bore as the cylinder, does the thickness really matter? If you could get a head gasket with the same bore as the cylinder, then there wouldn't be any "ledge" for un-burnt fuel to collect on. Since the OP is asking about compression and head gasket thickness, I figured this would still be relevant to the topic.
However, many times the chamber is wider than the bore. More common with aftermarket parts. In those cases you need to make sure the bore of the gasket exceeds the chamber diameter or you will not crush the fire ring.
Hope that makes sense.
I need to go re-measure the 706 heads that I have in the shed. I think the chambers are bigger (maybe 3.8") than the 5.3L bore (3.78"). That could be why GM used a 3.83" bore head gasket on the LM7.
I haven't measured any rec. port (823) heads yet. I suspect that they are bigger than the 4"-4.065" bore that they are used on, but smaller than the LS7 and bigger bores. That might make the 823 head a good choice on a 4.125" bore. That's assuming that you can find a head gasket with a 4.125" bore.
This might be over-thinking it, but if you are building an engine from the ground up, you might as well make everything as close to ideal as you can.
I spoke with DART and they were adamant about using gaskets made for their block only. They said the cooling holes won’t line up otherwise and I’ll have issues if I use LS7 or any other gasket. Weird.
Didn’t make sense if I’m using LS heads. I’m using Trick Flow 245 cc heads.
So the only gasket I can use is a Felpro 0.051 gasket.
