LC9 Catch Can Fills up FAST
I have a 2009 LC9 with about 40k miles, rings are gapped for boost and it has a Summit Ghost Cam. Just installed a turbo setup with a catch can (DS valve cover port thru catch can to top of intake, PS valve cover port to air filter pipe before turbo. I've been cruising around with no boost and find that I got about half a cup of oil (fairly clean) in the catch can in about 50 miles of driving. Is my PCV system sucking too much air thru? Even with gapped rings blowby shouldn't be that much.
Take a look here.... May have the info you need.
Can Install Gallery - Google Drive
