Timing chain damper
Old Mar 22, 2021 | 12:30 PM
The0nlyon3's Avatar
Default Timing chain damper
Hello,
does anyone know off the top of their head if a timing chain damper can be installed after the oil pump has been installed? Bolts between crank and cam gears
thanks
Old Mar 23, 2021 | 12:28 AM
1FastBrick's Avatar
It can not.
It must go on first prior to oil pump.
Old Mar 23, 2021 | 10:19 AM
The0nlyon3's Avatar
Originally Posted by 1FastBrick
It can not.
that’s what I thought so thank you for confirming. I appreciate it
Old Mar 26, 2021 | 04:54 AM
ls1 1990 VN's Avatar
It is a good mod to have.
I had a LS2 damper fitted with a Trickflow kit on my non drilled LS1 engine years ago & have a damper fitted on my now LS3
