Vacuum Pump Setup
Old Mar 17, 2021 | 02:33 AM
JJ_TURBO's Avatar
11 Second Truck Club
Default Vacuum Pump Setup
Will be using a vacuum pump on my high compression 416, AEI bracket and 4 vane Moroso pump, would this be a good idea to pull vacuum from? Already sold the valve covers on the pictures, will be getting a similar set.
Old Mar 22, 2021 | 09:41 AM
Fishmasterdan's Avatar
I have a vaccuum pump also.
I have mine out the top of valve cover. I would imagine the picture you show might be a little low and would end up sucking oil.
I actually used the oil fill tube with a -10 oil fill adapter
Old Mar 22, 2021 | 11:05 AM
WE TODD DID's Avatar
Front area of a valve cover, preferably not directly over the rocker arm oiling. Use Moroso 22635 fitting in the valve cover.
Old Mar 26, 2021 | 09:13 AM
64post's Avatar
12AN fitting in the center of the valley cover, only works with certain manifolds but less busy and cleaner look IMO. Save the valve cover to mount vacuum regulator valve.
Old Mar 26, 2021 | 11:24 AM
That is a recipe for filling the catch can with oil excessively fast.
There is A LOT of oil in the valley area which is the first obstacle, and the second one with when you put the regulator on the engine and not on the vacuum pump inlet side, it creates a "draft" through the crankcase which draws oil with it.
Old Mar 27, 2021 | 01:12 AM
64post's Avatar
yeah, those guys at Moroso must be all wrong with there supplied instructions for vacuum regulator mounting.
Old Mar 27, 2021 | 05:47 AM
The were, that’s why they started making these.
https://www.moroso.com/vacuum-pump-regulator22633/
And on top of that, I’m not sure why anyone would want to be pulling unfiltered air into the crankcase?
Old Mar 27, 2021 | 11:51 AM
64post's Avatar
Good to know.
