Darton sleeves, 5.3 gen4 block
Been doing searches, couldn't find a clear answer
I appreciate your help everyone.
It's be a roots blown, mechanically injected, msd mag fired combo for a nostalgia racing category. Roughly 15-20psi expected. Needs to make around 1100hp
Last Gen 1 deal was 9:1, 4.125x3.625 and was hard to slow down too run our 7.60 index. 1975# combo.
Was considering a smaller bore, keeping it around 332 inches. 4.00" with a 3.268 stroke
Another thing, not all Gen IV blocks can be dry sleeved. Some castings are Gen III internally, for instance any front drive 5.3. You must start with a siameesed bore block. 12571048 is the one I used most often. Make sure there is no coolant passage between the bores just under the deck surface.
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
One more question (i'll have a few i bet).
5.3 block at 4.125, save to make 1100hp? Is it pushing head sealing or bottom end strength?
if an iron block would be better, i'll do that.
6 bolt per cylinder for increased head gasket seal @ High Boost.
Priority Main Oiling for High RPM 7000+ RPM.
Iron Block is just inherently Stronger & More Stable.
I love the rocket your racing. The old school stuff is very cool to me, but I’m a notch away from being 50 years old, which is a whippersnapper compared to a few around here...
Head gasket sealing is not a problem with four bolts per cylinder. Use ARP New Age 625 studs and Athena head gaskets. I used to rethread for half inch Viper studs. No longer necessary. The New Age are actually stronger.
Past 1000 HP it is a good idea to fit steel main caps.
Steve
Steve Demirjian
Oceanside, Ca.
760-630-0450
