Check me?
Old Jun 18, 2021 | 10:32 AM
NYLS's Avatar
Default Check me?
I've been looking for a LS3/L92 to buy or build. Crate motors are nice, expensive, but come with a warranty. Scrapyard engines are kinda pricey for the unknowns they are, plus I'd have to tear them apart and build them anyway. So I'm thinking of building one from scratch with a mix of new/used parts. I'm looking at a higher RPM engine performance level - not extreme - just something that won't come apart on me, pump gas. I'd appreciate someone checking my numbers or part ideas to make sure I'm not way off base.
L92 LS3 aluminum out of 2010 car $1800
Heads & Valves $1000
Rotating assy., forged kit $2500
Cam $350
Manifold, stock used $350
Water pump $150
Oil pump $175
Wiring harness $400-600/w ECU
Misc parts and machining $2000 (any boring, decking, gaskets, pan, injectors, windage tray, etc.)
Not including alternator, headers, A/C, etc.
$8925 - so round it up to $9K for a custom, forged internals, 500+ HP engine. Surprisingly, going much over this by much at all would cost the same as a dressed crate motor from blueprint motors.
Anything glaringly wrong or could be done more efficiently for less?
Old Jun 18, 2021 | 10:41 AM
Darth_V8r's Avatar
Moderator
You don't need a forged assembly for 500 hp. stock bottom end is good to 8000 rpm as well. just saved you $2500
Old Jun 18, 2021 | 10:43 AM
NYLS's Avatar
Bare block, gotta get the rotating assy anyway, so knock half off would be reasonable.
Old Jun 18, 2021 | 11:01 AM
M33P's Avatar
1800$ for a bare block? Someone taking you to the cleaners.
Old Jun 18, 2021 | 11:07 AM
NYLS's Avatar
Have you priced LS3 L92 parts lately? It's $2500 retail new for a bare aluminum block. Scrapyard drop out engines are $6000+ for the same. If you can find a block in decent shape anywhere, they sell for $1800-2000. So I'm lowballing the block price. I've been scouring scrapyards, ebay, and elsewhere for months.
Old Jun 18, 2021 | 11:19 AM
AgFormula02's Avatar
4999 for a LS3 long block brand new. That is hard to beat.
granted, they are on back order till August.
Old Jun 18, 2021 | 11:25 AM
NYLS's Avatar
Yep. I'm eyeballing the crates from GM pretty hard, they've got a steep discount RN thanks to the delay in shipping. If you're not in a rush, getting a 500HP motor with a warranty is a pretty sweet deal right now. I'm so close to a crate at those prices with my build that it's a real tough decision. Only dif between my build and theirs is forged parts, and I want a safe 7000 rpm engine and theirs goes to 6600. So damn close, lol.
Old Jun 18, 2021 | 11:45 AM
Darth_V8r's Avatar
Moderator
i thought 1800 for for a JY shor block, not bare block...
Old Jun 18, 2021 | 11:47 AM
You will have a safe 7k RPM engine with a stocker. See Darth's post above. He has been there, and done that, repeatedly!
Old Jun 18, 2021 | 04:45 PM
grubinski's Avatar
They put the redline there because the intake and cam make it silly to spin it higher. Valvetrain may not be up to it, either.
Put a decent valvetrain in it, and you can spin it that high easily. Put the right cam in and it might even make good power up there ... but the intake won't be helping any.
The bottom end is not the limiting factor as far as getting revs out of these engines.
