Bending Oil Squirters for Clearance
I'm looking for advice from those that have bent them on:
- What method did you use to bend them (i.e. hand, pliers, small tube that fit over them, etc)?
- How much can/did you bend them side to side?
- How much clearance is needed?
Very important step in any build…you have to build the engine (mock up) a few times before you assemble it for the final time.
Basically this is a LS based 396 build (same bore/stroke as the COPO 396 - 4.065 bore x 3.825 stroke)
- LS9 Block
- LS9 CNC Heads
- Callies Magnum 8 CTW crank
- Callies Ultra Rods
- JE Pistons
- BTR Stage III Torque cam
- Kong LSA 2650
-Etc.
- LS9 Block
- LS9 CNC Heads
- JE Pistons
- Kong LSA 2650
-Etc.
On the block, I picked it up when they were discontinuing them. At that time it was cheaper than an LS3 block. It was around Christmas time and they were selling for just over $1300. I thought about buying a couple of them and now wished I would have. Also, I had an L99 with 100 miles on it, the CNC LS9 heads, and a new TVS2300 which I was going to build but then changed directions to I do my own build. Basically I was going to do several changes to the L99 and figured I'd have a better engine starting from scratch. I have sold all of the parts that I had for the original build and I have most of the parts for the build so I really don't want to change directions again. Also it took several months to get the rotating assembly since it was custom.
FWIW - this is going in a 67 Chevelle, mini tubs, DSE suspension, T56 Magnum. Also, given the car I like the idea of being able to say it has a 396 in it.
https://www.enginelabs.com/engine-te...or-ls-engines/
Your pistons will come out of the hole a little too.
