Plugging the AFM oil holes
Old Jun 24, 2021 | 12:02 PM
crewguy's Avatar
Default Plugging the AFM oil holes
Drilling/tapping the AFM ports in the block. which is preferred? Allen head bolts or Set screws?
Old Jun 24, 2021 | 01:11 PM
Set screws are fine. Use sealer.
Old Jun 24, 2021 | 04:48 PM
I tapped mine and used Allen head 1/4” plugs. Not sure how a set screw would work? Nothing can protrude over the top of the tower, or the valley cover won’t bolt down. I think Katech sells a rivet kit for the towers, but I have no experience with it.
Old Jun 25, 2021 | 05:31 AM
84ta406's Avatar
What is the advantage to blocking them off? The cover from my LS2 has a bunch of O rings already, I would assume to seal and block off? Looking around briefly I like the Lingenfelter rivets.
Old Jun 25, 2021 | 09:24 AM
The O-rings apparently are not always leak-proof.
Old Jun 25, 2021 | 11:40 AM
95sscamaro's Avatar
I use the LPE plugs no drilling required
Old Jun 25, 2021 | 02:55 PM
RonSSNova's Avatar
3/8 x 24 by 3/8" long allen head set crews work perfect. Use the correct tap drill.
I used red Loctite for a sealer.
Old Jun 26, 2021 | 11:34 AM
Jimbo1367's Avatar
What plugs can be used on a “in-service” vehicle? Not everyone has the option to do this while in the “ mock-up” or “build” stage
Old Jun 26, 2021 | 11:52 AM
BCNUL8R's Avatar
Old Jun 26, 2021 | 11:58 AM
cino's Avatar
I decided to go the same way after seeing Scott’s 434 build pictures. My block is still at RED awaiting custom billet caps. Scott, I forwarded Steve your pictures for reference and asked him to do this mod on my block.
