Fly cutting factory pistons
Old Jul 9, 2021 | 12:55 PM
showdog75's Avatar
Default Fly cutting factory pistons
So in a recent thread Summit Racing replied and made a comment about factory pistons being fly cut was a time bomb. I'm simply curious what the forum consensus is as for the safety and longevity is when fly cutting pistons.
Old Jul 9, 2021 | 01:20 PM
Corona's Avatar
Suicidal Racing is The Man With the Best Plan with a Factory Piston...and Cutting.
Hands Down...person to Talk to if you Really wanna know about it.
Guys do it all the time in the Quest of:
Cam Lift and more Compression
Old Jul 9, 2021 | 01:23 PM
Corona's Avatar
Consider GPI and there Record Holding stock Ls3 short block... There was Some Cutting going on using Ls3 or Ls7 heads.
Old Jul 9, 2021 | 02:32 PM
I’ve cut a few sets of OEM pistons and it really depends on how far you need to go. Deepest I’ve been with an OEM piston is about .060, and is still running great today.
In my circle track days, we custom ordered pistons without reliefs so we could cut our own reliefs as tight as possible, to make as much compression as absolutely possible. With those slugs, we ordered the crowns thick enough to cut on without worry, yet the piston had to be as light as we could get it as well.
Old Jul 12, 2021 | 02:05 PM
lazerlemonta's Avatar
My pistons are cut .120 me and hiossilver did them with Lindy tool. I have about 10k miles on it, 8200 rpm shifts and no issue. I have heard as much as .210 out of a LS3 piston being done.
Old Jul 24, 2021 | 04:32 PM
64post's Avatar
OEM pistons have little or no extra material under them. Hypereutectic cast pistons shatter like glass. I know people say they notch them but people skate on thin ice and sometimes bad things happen. Cutting material off them also changes their weight and there’s another problem.
Old Aug 12, 2021 | 11:30 AM
LilJayV10's Avatar
Well I'm about to boost my engine with flycut pistons...I will let you know how that turns out.
