ACL Main Bearings, Any good or stay away,
I am doing a LS2 build with a ACL Race bearing, one machine shop uses them and another says they flake,
anyone use ACL Main bearings lately, I have always used Clevite in the past,
Also confused about design, the normal Clevite has the groove on the bottom bearing about 80% the ACL is grooved 100% of the bottom bearings,
Dart recommends a bearings that has a 100% of the groove, Clevite does make a special LS bearing for Dart that is 100% grooved,
Will More groove add more Rod bearing oil, and Less Crank oil?
I have used the Standard ACL bearings in import rebuilds in the past with great success. Only 1 time I tried the Standard ACL bearings for an LS motor and I had an issue with one of the bearings. I decided not to use them for this application.
I have never tried the ACL Race Bearings in anything.
I have used both the Cleveite and the Kings brands in both Standard and Race bearings. They both work well in the LS.
This is just my opinion. I am sure others will chime in.
Thank you, just a little nervous, Hard to get a HX bearing in Clevite right now, so hopefully more will chime in,
Thank you, I am back and forth about keeping them in one of the 402 builds, good friend had someone build the motor that was to tight in a offroad race truck, so i just dont want any issues, i might save the ACL for another build, and found some Clevite today, I had a ACL flake in my 468, but i think it was a Oil cooler i build out of a inner-cooler core,
I haven't used Clevite in a long time, but I would have a problem with their main bearings being tight just on the #3 main for the LS stuff. It wasn't really a big deal though. I would later use ACL and never had that problem again, at least on blocks that I machined. The last bearings I used were King, which I actually liked a lot. There is something to be said about the design of the thrust among the different brands, but in my opinion, I think just about any brand will do it's job as long as you have a competent engine builder checking the clearances.
I have H-Series in the LSX and didn't have to do anything to the thrust bearing.
https://www.google.com/search?q=chec...T0PEP45mDqAg41
