High compression aluminum 6.0 in heavy car with AFR heads
Hey guys, my previous thread seemed to die with covid shutting the world down. I have some new parts but with the same question which is: Please help recommend a combo for a street/road trip friendly 4200 lb car. I'd like to do a high compression N/A build with a cam and tight converter to make it all work. This will be a daily in a sleeper wrapper. It'll be my only hotrod for the foreseeable future so it's not the conventional build on here. I originally thought I'd bore and stroke to limits but found out the skirt length doesn't play nice with the block I have. I heard there's some long rod piston combo that works?
L77 Aluminum 6.0 block
260cc AFR heads 69cc chamber
91 octane and e85
91 octane and e85
The following users liked this post:
Sebastian Draeger (08-23-2021)
Jimbo1367 (08-21-2021)
The following 4 users liked this post by 84ta406:
grubinski (08-28-2021), rkupon1 (08-22-2021), Sebastian Draeger (08-23-2021), tblentrprz (08-24-2021)
The following 2 users liked this post by KCS:
Corona (08-21-2021), Sebastian Draeger (08-23-2021)
The following 2 users liked this post by Bspeck82:
Sebastian Draeger (08-29-2021)
It's about being Content with a small bore and using What ever head fits the overall build the best ....
Who wouldn't take Stevens 402 with Cathedral heads?
Ls7 heads?
Dart heads were used....Why wouldn't a good set of Factory Ls3 heads do just as Good....
That Ls3 head test that Showed Mast Motorsports making X amount More Wouldn't show that great vs a 402 that wasn't 450 cubes with more compression..
If ones not happy with 600 to 700ish + on HP depending on Cam & intake...
It's about Reality and being Content with what's possible...if mores needed Build bigger and if so not spending
Twice on the block or the Work done. Out think the money pit....
Ls7 heads?
