Hollow vs. solid stem valves
Old Oct 5, 2021 | 11:14 AM
  #101
01CamaroSSTx's Avatar
I didnt think the LSA had hollow stem valves either, but was too lazy to search LOL.
https://help.summitracing.com/app/an...a-engine-specs
This is probably not correct info but Summit says LSA had hollow stems.
Old Oct 5, 2021 | 11:29 AM
  #102
grinder11's Avatar
WOW!!!!! Over 100 posts in just 6 days??!!! You'd think CF members posting up were getting free cable TV for 12 months courtesy of a moderator!!
Old Oct 5, 2021 | 11:35 AM
  #103
ddnspider's Avatar
Found this:
The LSA valve is 119-120
The LS3 Valve is 89g
Aftermarket Rev hollow stem is 92g
Given the weight, seems like it would be solid?
Old Oct 5, 2021 | 11:41 AM
  #104
Ferrea hollow stems weight in at 108-109g and I don't think it would be wise to run a GM hollow stem in a supercharged application.
Old Oct 5, 2021 | 01:25 PM
  #105
FormulaBoat's Avatar
I've seen mistakes published by GM, so honestly, no idea. I'm just trying to make sense out of it to end up with the valves I want.
Agree, I want solid stem for blower app as well, not revving it to moon, 6k or less, but then hold for a while. I may just end up buying one of each to sacrifice (send to out for metallurgical analysis) to then know what is what. On the LSA intake valve, I could just cut a valve up and look for any voids. On the LY6 exhaust, it really just says "Hi Temp Material", which could mean just stainless (not inconel). I'm OK spending $200 to know what I have and it being OE quality.
Thanks for publishing the weights, at least acts as a guide.
Old Oct 5, 2021 | 01:46 PM
  #106
Originally Posted by G Atsma
I got my info from Summit's LS engine database. It might not be totally accurate, plus GM might have changed the spec somewhere along the way.
Yet another error on Summits database. I’ve posted about this before. I love Summit Racing. Been buying from them for over 30 years, but I dont trust their database. I’ve seen too many errors on there. GM’s database as well has errors. Databases are written by humans and humans are prone to mistakes, especially humans that have likely never been inside an engine.
Old Oct 5, 2021 | 02:20 PM
  #107
Corona's Avatar
Watched a couple of more videos....
Billy Godbold and the EW video...I'll post both 1 for you and one for me....don't wanna Clutter things
Was hoping Billy spoke on valves 😢
Old Oct 5, 2021 | 02:25 PM
  #108
Corona's Avatar
Seen this 1st. On the phone with Holley for a Return on a Return in the 4500 x2 top. They Keep sending me a dual 4150 top. Going back to YouTube for the Billy video.
Give me a sec.. this one looked like a likable video with Boooooost.
Old Oct 5, 2021 | 02:29 PM
  #109
Corona's Avatar
👍 if you think about what Darin and Billy are saying it seems simple in the idea and how the system works out as a Air Pump.
Old Oct 5, 2021 | 04:32 PM
  #110
My Ferrera hollow intakes are 2.20” and weigh 98 grams. I agree with you and would not run a hollow stem in a FI setup.
Old Oct 5, 2021 | 05:01 PM
  #111
Corona's Avatar
I need a set. What's the length? Also 👍 on the post of the weight.
I have all my tulip tip exhaust valves @ 1.55 diameter.
Old Oct 5, 2021 | 05:06 PM
  #112
5.2” long for the TFS heads. Your setup may vary…
Old Oct 5, 2021 | 05:39 PM
  #113
Why is it that the Ferrea 2.20 hollow stem is 98g and my 2.165 weigh in at 108.75g
Now the exhaust valves come in at around 98g. I wonder if the L92 hollow stem has thicker walls or something compared to an LS7 valve.
Old Oct 5, 2021 | 06:02 PM
  #114
Corona's Avatar
Theres 3 avg lengths
1) 5.2
2) 5.4"ish: Mast heads/ All Pro: 5.2 to 5.4'ish, I believe​​​​​
3) Raised runners like the FED f710 head 5.6'ish
Old Oct 5, 2021 | 07:11 PM
  #115
Could be wall thickness I suppose? I weighed them myself. I thought I had pics, but I don’t. I do have a picture of one of Darths intake valves, which are Ti and bigger than mine.
Coated Ti intake valve looks like a freaking piece of fine jewelry.
Old Oct 6, 2021 | 08:23 AM
  #116
I've told my wife a time or two that men have a thing for precious metals too.
Old Oct 6, 2021 | 09:25 AM
  #117
IGN-1A's Avatar
Default Rev Kit for LS engines
I have used a "Rev Kit" in LS engines.
This allows for a lower pressure Valve Spring of less weight.
This method will extend "lite" valve life.
The cam lobe/ lifter will not be damaged if a Valve Spring breaks.
Old Oct 6, 2021 | 09:47 AM
  #118
Sturdy's Avatar
Just thought I'd chime in with weights as I weighed my valves, these were from Mamo Motorsports in a set of Tony's MMS235's with the hollow valve upgrade. Don't know the valve brand off the top of my head.
2.100" intake valve weighs in at 100g
1.600" exhaust valve weighs in at 98g
Old Oct 6, 2021 | 11:58 AM
  #119
Summitracing's Avatar
LS1Tech Sponsor
We apologize for the error in our LSA spec article and we are making an update. We encourage the community to send us corrections IF they have 100% verifiable knowledge. There are 46 Gen. 3 and 4 spec articles and prior to us publishing those, no one had gone through the nearly two year long effort to create the article. Our specs are more accurate than Wiki as a for instance and many others, but will always be a work in progress.
__________________
800-230-3030
www.SummitRacing.com
