Oil Pump choice ???
Something like this below (not my car) as yet air in through the trunk lid and out under the car. Clearly I will be changing the air cleaner location to fit this cooler / fan setup.
So get a higher pressure pump and not a volume ???
I use an extra quart of oil after installing oil cooler, that’s about the same % more the hv oil pump puts out
Anyway you can re-gear the car to get the rpms down to 1800-1900ish at 70 mph for mileage and a more enjoyable highway car?
High pressure will flow more oil (bypass less) with stock clearances versus high pressure high volume
High Pressure High Volume is to be used with larger clearances that can use the extra volume at a higher pressure. Using high pressure high volume with stock clearances does not flow more oil because the tighter clearance only allows X amount of oil to pass at X pressure and bypasses the rest regardless of pump volume and can actually put heat in the oil.
Kind of like someone using a higher volume fuel pump than needed and having the regulator bypass it right back to the tank heating up the fuel.
Something to think about besides the cooler is oil control in the pan if you plan on cornering hard and windage issues possible whipping the oil.
I looked it up and it was said a High Volume with added stuff like oil cooler etc....
pressure Is for Rpm...
I'm sticking with the Pressure pump vs ....
Any Hot Southern States (like myself) or Western Deserts States a oil cooler does what it says ...
https://help.summitracing.com/app/an...re-oil-pump%3F
I ask how many Factory cars or trucks offer a Oil cooler & what type of pump from the factory is offered for moving the oil throughout the engine.
🤣 With Factory Clearances and it's a Non Modified I wanna have funny with a Better than Stock oil pump
5 to 10 min Phone call. Best thing, like it was Said:
it Comes Straight from the Horses mouth...
An oil pump is a CONSTANT VOLUME device. Each rotation moves a certain amount of oil. It is designed in such a way that once the oil gets into it, it has no way to go, other than out the discharge. Unlike some other types of pumps, the "volume" that it delivers, DOES NOT CHANGE due to restriction.
The pump contains a "bypass" valve that is spring loaded, to allow the constant volume of oil moved by the pump gears, to return to the sump, once some pressure limit is reached. This prevents things from happening like, exploding oil filters, "hydraulic-ing" the pump, and so on, when the downstream restrictions (bearing clearances, and nothing else, ideally) are such that more oil is being delivered by the pump gears than can be forced through them, without excessive pressure developing.
The ONLY reason that there is ANY pressure AT ALL is because of whatever restrictions exist downstream of it. In the absence of the "bypass" inside the pump, the pressure will always rise to a value such that the flow through those restrictions is equal to the "volume" of the pump. If it takes 100, or 150, or 200 psi to force that much oil through the bearings, then that's what the pressure will rise to. If the pump can deliver more "volume" than can flow through the restrictions (bearings) at a safe pressure level, let's say 70 psi or whatever,, the bypass will open, thus allowing the "extra" pump delivery to escape back to the sump.
Coolers, filters, long lines, etc. are additional restrictions to oil flow. Maybe not all that much, but restrictions nonetheless. They require pressure to move the oil through them, or in another choice of words, create a pressure drop. So if your pump's bypass regulator is set to, say 50 psi, and the sum of all that stuff that's between the pump and the engine produce, say, 10 psi of pressure drop, your 50 psi pump will ACTUALLY only be delivering 40 psi to the bearings.
For this reason, the addition of coolers etc. requires higher PRESSURE to be supplied AT THE PUMP, so that after the pressure drop that those things create has occurred, there is still the desired pressure AT THE ENGINE to keep the flow through the bearings at an adequate level.
The pump can be thought of as "doing work", like any other pump; the amount of work it can do is characterized by its pressure vs volume curve. Pressure × volume = work.
Therefore, when adding coolers lines filters etc., the pump's regulator setting needs to be at a higher PRESSURE than it would otherwise. The pump VOLUME requirements are determined by the degree of restriction presented by the BEARINGS, and nothing else, same as without the cooler etc.
The pump MIGHT however, have to have a higher VOLUME capacity to be able to deliver the higher PRESSURE needed to overcome the added restriction of the cooler etc., at whatever FLOW RATE (volume) the bearings require to remain properly lubed and cooled, than it would if that extra "work" requirement wasn't there. Probably won't be by much but it doesn't hurt to provide for it.
I agree, the 10296 is a good all-around choice for most of these motors that don't have VVT etc., which require flow OTHER THAN that to the bearings. Its regulator has a stiffer spring and therefore it can deliver the higher pressure needed to overcome the restriction of coolers and such things, and may need some extra volume capacity to be able to do the extra work of forcing the oil through those other things.
Bearing Clearances wasn't even Spoken on. 👍
I may be mistaken but I think that's how it works.
