What do you think?
Old Nov 23, 2021 | 10:00 AM
Bigblock632's Avatar
Default What do you think?
Hey everyone, I have a Ls3 with a Howard's ASA cam, headers, gmpp dual plane intake, 950 quick fuel carb and planning on swapping it out for a cammotion junkyard dog cam... anyone have any experience with that cam an what do you think the hp difference would be coming from the ASA??
Old Nov 23, 2021 | 10:08 AM
speedfreak440's Avatar
Search "camapalooza" it's the title of a really good recent thread by Cam Motion where they test their Junkyard Dog and a bunch of other cams, really informative and I think you'll find the info your looking for in that thread.
Old Nov 23, 2021 | 11:13 AM
Thank you, will do..just looking for a little more power so not sure about the junkyard dog rectangular port cam or a gpi ss3..wondering if I would notice a difference in hp
Old Nov 23, 2021 | 11:55 AM
99 Black Bird T/A's Avatar
1) Howards's ASA Cam for LS3 226/236 .525/.525 with a 106 centerline
2) JunkYard Dog Cathedral Port LS Camshaft (232/244-111+4) 621"/.604" for "Single Plane"
3) GPI SS3
In./Ex. Duration
233/253
In./Ex. Valve Lift
.646/.637
LSA
112
ICL
+4
Between the three, I'd call Cam Motion and ask them to specifically spec a cam for your set up.
I think the JunkYard Dog & GPI SS3 with both make more power than the Howard's ASA. The GPI may carry the hp longer before falling off. The JY Dog will probably have slightly better manners based on less overlap.
Old Nov 23, 2021 | 03:09 PM
Mavn's Avatar
"I MAID THEESE"
Would look into a @Summitracing cam. They have cams made for short runner carb intakes that would probably make great power.
Old Nov 24, 2021 | 08:00 AM
Thanks everyone for the input so far...
Old Nov 24, 2021 | 12:38 PM
If It will be a noticable difference from an Asa cam to one of those above I will, just checking with ppl if they have swapped from the ASA an have had regrets or loss of power
Old Nov 24, 2021 | 03:34 PM
Summitracing's Avatar
LS1Tech Sponsor
The Cam Motion cams are well thought out and Carb intake cams generally have earlier intake closing points (seen as narrower lobe separation) to compensate for the short runner intakes. Ome thing is for certain and that's the ASA is a dog of a cam that's hard not to improve upon. Spend the extra little bit for a boat load of performance whether it's a Cam Motion, BTR cam or one of our Pro LS offerings. You won't regret it.
__________________
800-230-3030
www.SummitRacing.com
Old Nov 25, 2021 | 02:33 PM
Thanks everyone, so between the cammotion junkyard dog an gpi ss3, which one would be the best bet with a carb, car is just a weekend car
Old Nov 26, 2021 | 03:19 PM
LS1Tech Sponsor
The junkyard dog with its earlier intake closing point would be the better of the two for a carb style intake. We generally don’t recommend anything over .625 lift when using a stock rocker due to running off the edge of the valve stem so that’s another factor.
__________________
800-230-3030
Old Nov 27, 2021 | 05:23 PM
Thank you summit racing! 3200 stall be okay on the street with that cam???
Old Dec 1, 2021 | 10:20 AM
LS1Tech Sponsor
Yes, a 3200 stall will work with the junkyard dog CXM-03-01-0076 for the street.
__________________
800-230-3030
