Which 15W40 for built LSX?
Diesel oil is a bit like old-school flat tappet cam engine oil, it contains more high-pressure friction compounds, like Zinc Phosphates which is what "ZDDP" is on the label. This same material is the "AW" or anti-wear compound that gets added to "AW" hydraulic fluid.
I have a buddy that switched to Rotella on his LS7 that was spinning 7600rpms and ended up losing a few bearings. Coincidence? Who knows.
I've used Mobil 1 15-50 with zero issues. Valvoline VR1 is a fantastic oil and they offer it in 10-30.
Don't run race oil on the street it has almost NO detergents or rust inhibitors,
They do everything to it to prevent foaming and give up a lot of other stuff since it will be in the car less than a couple hours total for each use..
Makes sense if you consider they burn about 5 grand in fuel on a race weekend and the oil cost is 200 bucks.
LS7 to 7600 rpm is stupid -
RPM Limits 4 inch Stroke Crank goes into some details.
~7,600 rpm is over 5,000 fps (feet per second) when 4 inch stock stroke LS7 crank is used. That's a high crank speed if there much duration at that high rpm etc. Some folks have spun 4 inch cranks to ~10,000 rpm etc.
