l77 cam replacement
Old Dec 21, 2021 | 03:21 PM
petesripper's Avatar
Default l77 cam replacement
just picked up a l77 long block from a 2014 ppv to swap into a 72 nova, plans are to delete it and gap the rings and put some turbos on it, my question is what are the limits of cam lift and durtation with the stock flat tops and how much power can the block handle? already have a set of borg warner turbos and a holley mid ram and a shearer innercooler for the top end. the plan is to get it running on the sbe l77 and then build a forged short block and turn up the boost once i have a handle on what I'm doing. thanks
