Solid roller reliability
Old Feb 11, 2022 | 09:33 AM
SLOW SEDAN's Avatar
What I notice is higher rpm stability. I think the cam size means less than the lift. If you are running that cam at under 625 lift I'm sure it would last a good long time in llsr
Close .630
Old Feb 11, 2022 | 09:38 AM
grinder11's Avatar
If I was going solid roller, the lifters I think I'd go with would be something like Isky E-Z Roll lifters, or similar. Anyone trie running that style solid, and maybe adjustable pushrods?
Old Feb 11, 2022 | 09:46 AM
SLOW SEDAN's Avatar
The pushrods intrigue me, but doesn't seem like anyone shares their experience with them.
Old Feb 11, 2022 | 09:47 AM
AwesomeAuto's Avatar
I've considered swapping over to a solid roller more than a few times just for high RPM valvetrain stability.
Hydraulics haven't really let me down yet, and even though I can rev them to 8 grand, I wonder how much I'm giving up or risking up top.
Being able to do it on stock rockers has been nudging my decision a bit.
Old Feb 11, 2022 | 10:03 AM
Darth_V8r's Avatar
Moderator
Close .630
Splitting hairs there. With hot lash, your lift would be ~.620 anyway. it's not like you're pushing .650 or .680 or .750 lift like some crazy guys on here do (me)
Old Feb 11, 2022 | 10:24 AM
SLOW SEDAN's Avatar
True, but if going solid I would want more lift otherwise why bother. Put a turbo on your big lift setup then you'll be as crazy as some of us
Old Feb 11, 2022 | 04:22 PM
Where’s Mickey? He’s got over 30k miles on his solid setup. He will be here I’m sure.
I don’t have enough miles on mine to comment. Had a couple really busy years here and haven’t even had the Chevelle out since May. I’ve started it up and pulled it out of the shop a hundred times but haven’t put any miles on it. I will say regarding this subject however, that todays solid lobe designs, along with rocker stability in the LS architecture makes for a very robust and reliable solid roller setup. I’ve heard of many folks checking lash at 10k street miles and it hadn’t moved.
Old Feb 11, 2022 | 08:06 PM
jayyyw's Avatar
After reading a few threads, it seem more people are having issues with lifters failing rather than lash adjustments. Was not planning to have any machine work done to the block in order to run a larger lifter body; wanted to do a SBE deal. Still leaning towards doing a LLSR setup.
 Michael S. Palmer
Old Feb 11, 2022 | 08:10 PM
Corona's Avatar
You don't have to run a larger lifter.... I got normal size Ls S/R Lifters.
BAM lifters seems to be the hot trend with builders right now...
it's one of those spend once things as there rebuildable. New style bushed lifters eliminate any thoughts of failures.
Old Feb 11, 2022 | 08:12 PM
pdxmotorhead's Avatar
Very true.
Fwiw - Speaking of low performance 4 cylinders, according my local Honda dealer, they'd never heard of doing a valve adjustment. According to the owners manual with my 06 Accord, it needed adjustment at ~120,000 miles. Dealership was dumbfounded.
They said the same thing about the early gen honda fits, the guys that own them and pay attention know better, they need done about ever 35K miles, or suffer the consequences.. Single over head cam quad valve "i-vtec"
On the other hand my 57 Fairlane that had solid lifters ,, it needed them checked, and usually you'd need to tweek 1 or 2 , but you knew, it would get noisy..
Old Feb 11, 2022 | 08:17 PM
jayyyw's Avatar
I was reading about BAM. I actually got a random e-mail last night from BTR. They now sell BTR/BAM roller lifters. Thinking this is the route I will be taking once I'm ready to start collecting parts.
Old Feb 11, 2022 | 08:26 PM
  #32
Corona's Avatar
Bump....re read my edit..
I worried more about lifters than a cylinder head and stress on behalf of either part.
Old Feb 11, 2022 | 08:29 PM
  #33
Corona's Avatar
Who loves you... one person who Spoke is a Pro Stock engine builder.
https://www.yellowbullet.com/threads...fters.2661240/
Old Feb 11, 2022 | 08:38 PM
  #34
jayyyw's Avatar
I have set up three LLSR setups using this method and have greatly enjoyed them:
https://ls1tech.com/forums/showthrea...1811105&page=1
I honestly prefer this method over the adjustable rockers for lift up to .625 for several reasons.
1. No valve cover bullshit
2. Adjusters do not come loose
3. They are QUIET
4. Lash did not change even after 10k miles.
Every llsr I've taken down has been unrelated to the llsr. My 346 bottom end was done. That cam and lifters went into another engine. My 428, I did a head swap and my well-documented pushrod error (missed the cup). Prior to the head swap, that cam had close to 10k on it.
Honestly I've had more trouble out of adjustable valve trains than shimmed, non adjustable valve trains for daily drivers.
I plan to run a LS7 based head. How would you do this with pedestal mount rockers that don't use a rail system? What's the max lift you would run in this configuration? Ideally I want to be in the .700" lift range or greater.
Old Feb 11, 2022 | 08:44 PM
  #35
jayyyw's Avatar
Yup, read that post last night
Old Feb 12, 2022 | 02:41 PM
  #36
Darth_V8r's Avatar
Moderator
If you're using stock lifters (no roller tip), I would stop at .650 lift. Even then, I would run lash caps to spread out the scrubbing. you should run lash caps if you run titanium valves, anyway...
If you want .700, you'll need a roller tip. the good news is, if you are using the stock-style pedestals, you can put a machine shim under the seat, and it will conform just fine. You will want to be within .008" so that you can use super flimsy shims.
If using a YT, for example, the rockers are in pairs. You don't want to be stupid off between the valves, but if there is a .003" difference in shim height between the two sides, it's fine you'll have that much variation on accident from stacked tolerances. What I would do is first set your wipe pattern. Then, measure all 16 pushrods individually to the nth degree. Then order custom pushrods from someone like Manton. It's not unusual to end up getting several lengths. As an example, if I get 9 measurements that all are between 7.830 and 7.836, I'll order all 9 at 7.838, counting on a +/- .003 variation from Manton. then measure all of them so I can optimize from there. Ideally, every single one of the pedestals will want .005" shim. if I end up less than ideal, then I try to play the mix and match game to get the shims the same or nearly the same on both sides. It will slightly affect wipe, but not really. For example, if the ideal shim for wipe is .120", and you add another .005, it's not the end of the world, and you probably wouldn't be able to see the difference on the valve tip if you re-did your wipe. I usually will order a couple extra at each length to give myself a few more options for the mix and match game.
I think that is enough for you to follow the logic? You're pretty savvy on this stuff, so beyond that, if you need anything, just ask
Old Feb 12, 2022 | 06:35 PM
  #37
Fishmasterdan's Avatar
Springs are really want sets lift limits.
Over .800 lift. Heads get expensive quick cause you are pretty limited on spring selection. I had to go to a brodix head made for solid springs. Still waiting on rockers. Several months to get a set of solid roller adjustable rockers.
Old Feb 13, 2022 | 06:33 PM
  #38
Mickyinks's Avatar
I got 30,00miles out of my cammotion solid roller, daily driven. I broke a valve spring which damaged the lifter which damaged a cam lobe, all the other lobes looked mint. I also replaced the yt rockers , I broke one and a few other were showing signs of wear
Adjusting lash isn’t an issue at all. Lash shouldn’t change , if you do find you have more adjustment to one than the others , have a really really good look at why
ill be changing valve springs once a yr , replace rockers every 2nd yr
That May change due to ill be going to titanium valves and trying a different spring in December this yr.
just go the lightest possible valve train, replace springs regularly, check rockers regularly , if those things are done your cam will last a very long time
Old Feb 17, 2022 | 02:30 AM
  #39
jayyyw's Avatar
Thank you. Yes, it makes sense.
Old Feb 17, 2022 | 02:31 AM
  #40
jayyyw's Avatar
Thank you.
