Cammotion cam choice
Old Mar 1, 2022 | 11:19 AM
Bigblock632's Avatar
Default Cammotion cam choice
Ok guys real quick, contacted cammotion an got 2 cam recommendations an just looking for what you guys think between the 2 or if anybody has used either with some insight... junkyard dog rectangular port or titan king..1984 Monte Carlo SS ls3 swap 950 quick fuel carb, GM dual plane l92 intake, headers, 3200 stall converter, 3.73 gears weekend toy, won't be drag racing this, currently have Howards ASA cam.. thanks!
Old Mar 1, 2022 | 12:16 PM
Cam specs??
Old Mar 1, 2022 | 12:36 PM
68Formula's Avatar
If you look at the valve events, the difference is only the earlier intake closing and a slight change in exhaust opening (even the lift is the same).
JD vs. TK
IVO: 6.5/6.5
IVC: 43.5/45.5
EVO: 58.5/57.5
EVC: 6.5/6.5
And resulting overlap is the same.
Either will give you more top end than the Howards ASA. Between the two the Junkyard Dog would be a better choice, as the IVC is closer to the ASA therefore mid-range should be similar. Which is probably why they recommend a slightly higher minimum stall range on the Titan (min. 3600). So for your gears and stall combo, JD would get the nod.
Old Mar 1, 2022 | 12:37 PM
Cam choice 1- Grind # XA232/365-XA244/355-12.5+3 Hydraulic Roller CamshaftMaximum performance Strip - RaceDuration at .050: 232/244112.5 Lobe Center Angle with a 109.5 Intake CenterlineLift with 1.7 Rocker Arm Ratio: .621"/.604"
Cam choice 2-. Grind # XA229/365-XA245/355-12+4Aggressive Street / Street-StripDuration at .050: 229/245112 Lobe Center Angle with a 108 Intake CenterlineLift with 1.7 Rocker Arm Ratio: .621"/.604"
Old Mar 1, 2022 | 12:48 PM
Thanks 68formula..guess it's really splitting hairs after seeing the difference in valve events
