BTR Stage 4 Cam and Milled Heads
I've got an LS3 out of a 2010 camaro that is bone stock that im about to drop into my 1969 camaro. While its out id like to refresh the top end with new LS7 lifters, trays and do a cam and .660 springs while i'm at it. I had the BTR stage 4 LS7 cam in my 2008 z06 and absolutely loved how it sounded and it made great power.
As such, i'd like to run the btr stage 4 LS3 cam in my new motor. The question is, can I mill the heads at all without running into PTV issues? Anyone here running this setup? I dont have to mill the heads obviously, but a bump in compression never hurts!
Appreciate any feedback.
BTR CAMSHAFT - LS7 - N/A STAGE 4
Specs: 247/258 650/630 112+3
28.5 degrees of overlap in a 427 LS7 is a lot mildwr than 28.5 degrees of overlap in a 376 LS3. I think the missing 51 cubic inches will make a difference in driveability if driveability matters.
Seems like a good argument 4.1 inch stroker kit to make a 427 LS3 to me!
The following users liked this post:
01CamaroSSTx (02-24-2022)
i think the missing 51 cubic inches will make a difference in driveability if driveability matters.
The following 2 users liked this post by Corona:
01CamaroSSTx (02-24-2022), Double06 (02-24-2022)
I saw a chart once that went through different cubic inches and cam degrees etc. Basically in your range there, every 70-80 cubic inches was like a 10 degree cam duration and you are 50 so say like 7-8 degrees less to get you same RPM range with 427 with 376.
jayyyw (02-24-2022)
Yes wow, sorry for the confusion. I absolutely mean the stage 4 LS3 cam. I was simply making a comparison to how I liked the stage 4 cam in my LS7. I'll edit the original post and summarize here:
Anyone running the btr stage 4 LS3 cam and milled their heads .010-0.30?
If I were you, I would call BTR and ask them about PTV. My guess is that you'll be OK with a little bit of milling, but I can't say for certain.
If you only need .010 taken off just use .040 head gaskets. It will also tighten quench up.
jayyyw (02-26-2022)
Even with both cams being BTR cams, the stage-4 LS3 and LS7 are two completely different animals.....nowhere near being similar.
Also, the BTR stage-4 cam with stock heads? BTR says this on their web site; "For proper piston-to-valve clearance, you cannot mill your cylinder heads without the possibility of needing to flycut your pistons."
BTR CAMSHAFT - LS3 - N/A STAGE 4 - 33350135 (briantooleyracing.com)
So no....milling is not a good idea.
KW
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
