Stroker kits questions
ps. It’s a 402 kit with Texas speed I beam rods
I would start with shimming what you have as that would be the cheapest option. If you want to set that engine up on a dyno and then drain/add oil to measure HP as it correlates to oil level, that would be the only way to really know what you've got.
The most important thing is no contact with the rotating assembly and the pan, so as long as you have clearance, the rest is gravy.
If you use our EGM-241 windage tray, you don't have to worry about any of that. It bolts on like factory and everything is where it should be. It's also made from aluminum, so it's less than half the weight of the factory windage tray. I highly recommend using our windage tray instead. At $149, it's not a huge investment compared to a factory windage tray either.
No matter what windage tray you use, you won't have any issues with interference with the oil pan baffle, there is plenty of space for that.
