Gen 4 with 317 heads
I recently bought a gen 4 6.0 off the old facebook market place. When I was picking it up I didn't even think to see if gen 4 6.0s came with 317 heads. I did some googling and it seems like all the gen4 6.0s came with rec port heads.
Did any gen4 6.0s come with 317 heads or did I get got?
Thanks,
You're right- the ones you mention have iron blocks and rectangular heads.
What is the intended usage for your engine?
If you use the Gen IV 6.0, you will need to relocate the knock sensors to the side of the block, and the cam sensor is now on the timing cover. You will need to switch the 2 outer wires on the sensor plug for it to work with your wiring harness.
No matter which engine you got, both the 243/799 cathedrals and the 823 rectangulars are way better than the 241 heads you mention. Stick with the heads that come on the engine.
I *think* it is supposed to be an LY6. it came out of a 2011 express van. Has the VVT timing cover and stamped '6.0 IV' on the passenger rear. I'm really just bummed I didn't get the rec port heads since they flow so much more.
$500 isn't bad for a gen 4 short block. But I guess we'll have to see what the machine shop says before I get too excited
Was the van set up for CNG/LPG? It could be an LC8 also iron block/rec port heads.
Or the L96 was made that year, also iron/rec port heads.
If it has an iron block it does NOT have cathedral heads. LS2, LFA, and LZ1. We have gone over this.
If you got a Gen IV iron block with original heads, you HAVE rec port heads!
BUT the seller said it was a Gen4 6.0 and he said it is stamped "6.0 IV" and has a VVT timing cover.
So it is probably a gen 4 6.0 that someone robbed the 823 heads and slapped a set of 317 heads on to sell, so I would be fairly concerned about what is under those heads.....
