Any reason to use LS2 heads on an LS3, or did engine shop really screw up?
Cathedral heads on an LS3 seems to be a choking point unless it was like what ddnspider said and a FAST LSXr 102 or a Holley High Ram was up top.
The following users liked this post:
G Atsma (04-17-2022)
68Formula (04-18-2022)
If I were the owner here, I would request a return number, and send it back. If the shop gave me any resistance, I’d remind them that social media posts with pictures and shop names could really hurt business. After the refund, I’d go somewhere else. There’s no telling what’s wrong in the rest of the engine.
The following 7 users liked this post by Che70velle:
99 Black Bird T/A (04-17-2022), G Atsma (04-17-2022), grubinski (04-17-2022), jasons69chevelle (04-18-2022), Ls7colorado (04-18-2022), and 2 others liked this post.
THIS!!!
and dont get a fitech.....
I wouldn’t trust that shops work. Probably just slapped it all together without measuring and torqued with a battery powered Dewalt. If you have non factory head bolts, pull the valve cover and see if the head studs or bolts are torqued to spec. Heck maybe see if any of the bolts are torqued to spec valve covers, front/rear, valley covers. That’s just sad attention to details.
Wow! That's mind boggling!
What everyone else said. The fact they missed what's circled in blue...send it back ask for refund. Chevelle is on the mark.
File with credit card company or whatever it takes.
However, it the motor sat for a long time, had no warranty or warranty has expired, it may be an uphill battle.
Good luck
G Atsma (04-18-2022)
This has to be one of the poorest examples of a "professionally" built engine I have EVER heard of. Sad. If it was me, I'd send the whole thing back, and ask for a total refund. Then take your business someplace that has a good reputation. My good God, I was better with a wrench at 12 years old than these idiots......
#32
I did put a scope in to check out the cylinders and they look freshly honed and the pistons look clean, so I do think it's a fresh rebuild. Whether it was done right and with the right stuff I don't know. It's supposed to have forged rods, though without getting if off the pallet and pulling the pan I can't really confirm. I'm not going to take that step unless, for some reason, he ends up still with this engine.
The following 5 users liked this post by ddnspider:
G Atsma (04-18-2022), grubinski (04-18-2022), Ls7colorado (04-18-2022), siggyfreud (04-18-2022), theunderlord (04-18-2022)
#35
The tag that came on the engine says "Stock GM". It was delivered the last day of November though we only fully unwrapped the engine a few months ago as we started the actual build. We did check through all the paperwork, accessory boxes, etc., and took enough plastic off to verify the belt drive looked right, mounted accessories looked good, etc, but not enough to see the wrong heads were installed. Lesson learned apparently . . .
#36
Connor or Bob need to get a stern talking to.
The following 2 users liked this post by theunderlord:
G Atsma (04-18-2022), wannafbody (04-18-2022)
#37
"Stock GM" Means ZIP. A blanket term if there ever was one....
#39
I think it's clear where Connor left off, and Bob took over.
#40
What's with the 317 at the top left corner of the tag?
