Opinion Requested: 454 vs 427
Old May 30, 2022 | 05:33 PM
  #41
Originally Posted by Utinator
I don't think you can go bigger than a 4.125" bore with any block right now. That's the biggest bore I was told that could be done. That was with the 6.2L block. The 6.0 and 5.3 blocks would have smaller max bores. Basically, you can only get OEM-sized dry sleeves right now. Supposedly, Darton has a dry sleeve for the 6.2L that can go out to 4.125". At least, that's what I was told by the machine shop that talked to Darton.
I found some 6.0L and 6.2L blocks for $200 in Austin. I don't know how bad the damage is, but I was going to go look when I get time. It costs $200 per cylinder for dry sleeves. So, about $1,800.00 for a block, potentially with a 4.125" bore. That's way cheaper than any other option out there. I haven't even seen an LS7 block for sale in years.
Call Steve @ RED. He’s been sleeving blocks for 50 years and is Dartons R&D guy. He will shoot you straight. 760 630 0450
Only guy I trust for sleeving. He’s done several for me.
Old May 31, 2022 | 08:29 AM
  #42
F me's Avatar
With the expense of sleeving and all the other machine work involved, would be better in the long run to just buy an LSX454 bare block with a 4.185 bore? New block less than double the cost of all the machine work and a bigger bore to boot. The LSX block comes honed ready to go, but of course double checking is prudent. Cast iron might be a concern.
Old May 31, 2022 | 08:43 AM
  #43
NHRATA01's Avatar
ERL did really nice work. Looks like your motor will be a beast. However, imho, pistons with such little skirt area are bound to rock. That said, the Diamond pistons in my LS7 are no shining star in that department, either. Its not just Diamond, either. There isn't much any piston manufacturer can do with the deck height being what it is, combined with a 4.00", or longer stroke. But hey, we know when we build them it's not going to be installed in the family sedan, and go for 200,000 miles. It's not your Grandpa's 454, with 275hp!!! That is one place that favors the original 427 big block, and that's the 3.75" stroke. Oh well. I know my pockets aren't deep enough to do it, but I know there are people out there that could do this. "This" being a C5/C6/4th & 5th gen Camaro/4th gen Firebird with the ZL1 big block in place. I've never seen one, especially a C5 or C6, though there are probably a few out there.........Somewhere..........
Getting off topic a bit but there was a guy years ago who swapped in an 8100 into a C5. Problem with the 8100s though was most of the traditional BBC parts didn't work on them so aftermarket was very limited and it didn't make any more power (though of course more torque) than an LS. As far as old school carb'd BBCs, there's plenty in 4th gens, probably a few track setups in C5s and maybe 5th gens out there. At that point though you're more strip than street. But the instant throttle on power of big cubs NA is pretty fun
Old May 31, 2022 | 08:46 AM
  #44
Darth_V8r's Avatar
Moderator
I"m 4.190 on a darton dry sleeved block from RED
Old Jun 2, 2022 | 05:29 PM
  #45
Utinator's Avatar
That sounds awesome! Was it done recently?
Old Jun 2, 2022 | 05:32 PM
  #46
Utinator's Avatar
Originally Posted by F me
With the expense of sleeving and all the other machine work involved, would be better in the long run to just buy an LSX454 bare block with a 4.185 bore? Cast iron might be a concern.
Yeah, that's a hard pass for me. I don't want any "junk iron" in my car.
....and then the fight started.
Old Jun 2, 2022 | 06:24 PM
  #47
01CamaroSSTx's Avatar
Yeah whateva.. Frankly I'd be more worried about the internals staying together. N/A not so much but 20-30psi I'd be concerned.
Old Jun 2, 2022 | 07:46 PM
  #48
F me's Avatar
Junk Iron? Really? Cast iron can handle more NOS or boost than any aluminum block. I'm sure when you have 1000 HP that extra 100 pounds of junk is really gonna matter!
Old Jun 2, 2022 | 08:33 PM
  #49
That block was sleeved in June of 2020.
Old Jun 2, 2022 | 09:13 PM
  #50
Darth_V8r's Avatar
Moderator
Yes. It was done right before the pandemic got going. I managed to get all my parts right before all the shortages started
Old Jun 3, 2022 | 01:31 AM
  #51
Corona's Avatar
idk....
https://www.yellowbullet.com/threads.../post-73671200
https://www.yellowbullet.com/threads.../post-73679096
Old Jun 5, 2022 | 05:31 PM
  #52
Utinator's Avatar
A lot has changed since then. I don't think you can build that engine today. I'll keep an eye out for a 6.2L block. If I can find a rebuild-able block for cheap, I'll grab it, but I'm not getting in any hurry to build another engine until I build a garage. I need a place to work first. I have been using my dad's shop, but it's not close.
Old Jun 5, 2022 | 05:35 PM
  #53
Utinator's Avatar
I'm just messing with you. I know that iron blocks are stronger. I just don't want the extra weight in my car. You can't use that much hp on the street anyway.
Old Jun 5, 2022 | 05:48 PM
  #54
My 01 SS has all of its creature comforts and weighs 3,840 with me in it and I can tell you that you're not going to notice there's another 100lbs over the nose.
Old Jun 6, 2022 | 03:54 PM
  #55
440_Stroker's Avatar
I will disagree. I could definitely feel the front end weight difference with doing a LSA style blower and all the extra components on my LS3 C6. Probably more so in a C6 as it was only a 3,180 lb but it added over 90 lbs to the nose and though it wasn't terrible it was noticable.
