DOD Delete….. very low oil pressure
Old May 11, 2022 | 09:08 PM
FleXJ's Avatar
Default DOD Delete….. very low oil pressure
So my wife’s 2010 Yukon threw a lifter so I deleted the Afm, tapped and plugged the lifter ports, new stock non Afm cam, new lifters. Truck now starts and runs great but let’s out a cloud of smoke on startup and has next to no oil pressure. I did not remove the oil pressure relief valve, could this be the culprit? I’m using the original oil pump.
Old May 11, 2022 | 11:33 PM
theunderlord's Avatar
specifically what oil pressure? blue smoke or white smoke?
Old May 12, 2022 | 05:49 AM
FleXJ's Avatar
It’s around 15 psi cold and drops to around 5 when warm and flashes to shut engine off, I’d say the smoke is more white
