Carb swap L92
I got a 2014 L94 that I want to carb swap? What do I need to do to the internals? I see DOD and VVT, but I have no clue what it means.
I am using MSD for ignition for now, but I got front cover and cam gear to run distributor later on. It also has lobe for mech fuel pump.
I got a 2014 L92 that I want to carb swap? What do I need to do to the internals? I see DOD and VVT, but I have no clue what it means.
For educational purposes here, DOD stands for Displacement On Demand, and is a method of using oil pressure to hydraulically disable 8 of the 16 lifters, turning the engine into a V-4 for fuel mileage purposes. This would only occur at very light load. GM’s stab at better mileage to help meet the EPA requirements, and honestly some folks still give a rip about fuel mileage. I’m sure it would make a sale or two. VVT stands for Variable Valve Timing and is a method of using oil pressure (again) to hydraulically retard or advance the camshaft to aid in low end torque or top end power, whichever the engines computer felt was necessary to help, according to rpm. This technology is very cool to me, but I’m a techy type of performance guy nerd. It works for an all around street cruiser. If your building an all-out max-effort drag car or standing mile engine, VVT is not for you. The first engine I built for my Chevelle had VVT, with an aftermarket Mast Motorsports VVT camshaft. I liked it, but was hypnotized by the HP drug and built the sleeved 434 I have now. I get bored easily with my builds and have to change things, hence the 434 build. Nothing wrong with the aluminum 6liter with VVT at all. It had 1500 miles on it, and I pulled it out.
Many here will rag on you for going carb and distributer with an LS platform, so be ready for the insults. I say build whatever makes you tick. If it’s a carb, do it. If you enjoy the challenges of fuel injection, do it. Pro charged 500 cubic inch, 3500hp Hemi? Do it. To each there own.
Im still stuck in the 2000's LOL
In that case I would slap a carb on that baby without a second thought.
Carbs are clean and simple. No spaghetti wiring, no reflashes, and they have worked for like 100 years.
Do it. I am doing two EFI, but I want to do a carb one eventually. Leave the distributor home though.
