NA C5Z Build
Old May 2, 2023 | 01:54 PM
  #61
02EBC5Z06's Avatar
Originally Posted by spanks13
Which spintech is that and what size oval tubing? Dayum!
Pro bullet stainless. 5".. So the inlet and outlet oval measures 6 x 3.5
Old May 2, 2023 | 02:37 PM
  #62
spanks13's Avatar
That is some serious flow lmao
Old May 2, 2023 | 09:28 PM
  #63
DualQuadDave's Avatar
Originally Posted by 02EBC5Z06
Couple updates. Paris finished the heads and manifold up. Got one head off to the machine shop so they can check PTV and finish up the bottom end. Chambers came in on the lower side of what we expected. Once opened up for the bore, he measured them at 62cc. We expected them to be around 69 or 70cc and then mill them down a bit to get 67 or so. He worked them a bit more and raised it up to around 64cc. So, with an LS9 gasket instead of an ls1 (051 gasket), should bring the static in around 14.2-14.3:1.
Still waiting on Liberty to get the gears back to us for the trans. Also found the spider gears in the diff cracked, so need to replace those. New Spintech muffler and turn down showed up though, so that is cool haha. Hoping I can get away with just one of these under the car, but I will have my friend set it up to add a second in the off chance one isn't enough.
Your porter burr finished the chambers??? The intake ports, sure, but IDK about that on the comb chamber. That's like adding hundreds of high point detonation possibilities.
Old May 2, 2023 | 09:46 PM
  #64
02EBC5Z06's Avatar
I think we can agree that the burr finish topic can be talked about till we are blue in the face. I've seen/read a number of threads where it was used on the chamber and made more power vs not being done prior. Half intake ports, full intake ports.. Etc.. It's definitely nowhere near the roughness of the ports. It's very, very smooth to the touch. He's done some good stuff over the years from SAM, to TEA, etc. If he felt that the finish was necessary, then I'm with him on it.
I know most people always expect a cnc/smooth as glass port.. Otherwise they feel they're getting ripped off lol
Old May 2, 2023 | 10:19 PM
  #65
You are right on the discussion around the burr finish works or not debate. I have seen enough evidence that it doesn't hurt on the intake ports, maybe adds a touch of power on some combos. The comb chambers, though, I have never seen proof either way that it works or not. No one to my knowledge has ever done any published testing on it. That being said, your combo is dedicated e85 build, correct? That may help specifically with that fuel since the mixture volume of fuel is so much greater. in theory would help promote combistion. That would be interesting to hear opinion on.
Old May 2, 2023 | 11:01 PM
  #66
B4CMaro's Avatar
Eric weingartner did a series of videos of "internet porting heads" he tried a bunch of ideas from the internet, separating fact from fiction with flow data. Worth a watch.
Old May 3, 2023 | 03:38 AM
  #67
02EBC5Z06's Avatar
Yes, it is an e85 car and that was a major factor in the chamber having the finish it does.
Old May 3, 2023 | 06:51 AM
  #68
02EBC5Z06's Avatar
I will check it out. The burr finish though, from my understanding isn't done to affect flow, but to aid in fuel/air atomization to keep the walls from wetting. Some sources even stated it helps aid in intake charge cooling, which does make sense if the fuel is staying in the air charge and not moving along the walls.
Another benefit that most claim is better on and off throttle performance. There's a great thread on speed talk from years ago that I'll dig up and link here. It's 70 pages of back and forth, but a lot of great info in there.
  #69
02EBC5Z06's Avatar
https://www.speed-talk.com/forum/viewtopic.php?t=41774
Old May 3, 2023 | 01:27 PM
  #70
Ryans99ls1's Avatar
I am surprised you are dumping the exhaust under the car with how much you drive that thing.. but maybe I am just old and grumpy now?
Old May 3, 2023 | 01:39 PM
  #71
02EBC5Z06's Avatar
You are just old my friend. I'm actually in your neck of the woods right now,
Old May 15, 2023 | 06:46 AM
  #72
02EBC5Z06's Avatar
Made some progress this weekend on the Holley install. Harness is routed from the location of the ecu through to firewall for both the main and DBW harness. So far so good on where everything will land. Be nice if you would get a bit better harness than what they send though, along with the fact that it could be a bit more tailored to what kit you purchase. . For example, I don't need a connector for a tps, iac, etc when I purchased this kit specifically for a dbw car. Not a big deal though, but just extra clutter.
Old May 21, 2023 | 07:43 PM
  #73
02EBC5Z06's Avatar
Stopped by the machine shop Friday to see if they were finished up yet. All that's left is indicating the bell housing and balancing the clutch and flywheel. Picked up some offset dowels for them and dropped those off Saturday morning.. Everything should be ready to be picked up by Tuesday or Wednesday. My friend said he talked to liberty, they claim the gears are finished.. So hopefully have those back this week.
Old Jul 5, 2023 | 08:57 AM
  #74
02EBC5Z06's Avatar
Guess I haven't updated this in a minute lol .. Have had the engine home for awhile now, got the heads on, measured for pushrods and luckily only needed to order 4 from Manton as 12 others I had were within a couple thou of most of my measurements/groupings. Got the engine sort of in the car the other night, but I had to have my friend weld in a starter gear/flywheel opening cover so nothing would get into the bell and jam up since it is a rather large hole.. well, the cover he welded up was a bit large so it actually interfered with the frame rail of the car, so I had him cut it down a bit.
Here is just a big photo dump lol
Old Jul 5, 2023 | 11:50 AM
  #75
Heads look interesting, did they ever give you flow #'s on them?
Old Jul 5, 2023 | 12:17 PM
  #76
02EBC5Z06's Avatar
His flow bench reads lower than TEA's does, but they were around 340+ on the intake and he said they would easily do 270+ with a pipe.
Old Jul 5, 2023 | 08:29 PM
  #77
jayyyw's Avatar
Looking good
Old Jul 5, 2023 | 08:34 PM
  #78
02EBC5Z06's Avatar
Originally Posted by jayyyw
Looking good
https://media.tenor.com/IoO9Y09oQG0A...aining-day.gif
Old Jul 12, 2023 | 09:37 AM
  #79
logan2ss's Avatar
Cant wait to see what this thing puts down!
Old Jul 12, 2023 | 10:02 AM
  #80
02EBC5Z06's Avatar
Same! I think the motor would easily make 700 flywheel comparing to various other builds.. Not that the numbers matter too much to me. But it's gonna be a riot regardless since I put the lighter flywheel and the 3.90s in it.
