Engine Noise
Any comments/suggestions welcomed
Regarding cutting open the filter... Watched a video online where they, drained the oil filter, used a tool like a large pipe cutter to cut the top off and removed a cross section of the media for inspection. Would using a hacksaw to cut through the end of the filter work without contaminating the media too much or do you really need to use one of the filter cutting tools?
-Hot Rod Confucius
When checking the garage I found an exhaust pipe cutter with cutting wheels that will fit over the filter so that should work perfectly. Also getting a Blackstone oil test kit and will send off an oil sample.
I'll start it up one more time for a quick listen with a mechanics stethoscope and see if I can find the general area of the noise.
Now just need to get to it, hopefully by the weekend I'll have the filter cut open and see what's there!
Thanks for the replies!
At the point of either replacing the cam/lifters etc... or pulling the motor. Motor has ~120k and was running fine, then the noise started. What causing this type of wear/damage on the cam? Had good oil pressure and was maintained well as far as I know regarding oil changes with quality synthetic 5-30w.
Personally if it were me I'd rebuild the engine with better rods and pistons. The stock ones don't owe you anything and I'd hate to see another LS1 block go to waste due to a rod letting go.
On the fence about pulling the motor and will probably just do the cam/lifters/heads and see how it runs. Was running well until the noise started, but you couldn't notice any issues and only first noticed the noise when the window was down backing out of the garage and pretty much parked it. Just been sitting for a few months until lately got around to working on it and seeing the issues causing the engine noise.
