Oil pressure dropping at high RPM
Got a weird oil pressure problem. Looking for some insight. He's what I have and what I'm dealing with. 6.2L stock bottom end rebuild with maybe 700 miles on it.
Main bearing clearance where .0017-.0018. Rods .0024-.0026 melling .
Melling 10295 pump
New barbell.
DOD plugs and cover
New oil pressure sensor and i confirmed its accuracy at ilde and parked reving with a mechanical gauge.
Used sae 30 on first 10 miles then dumped oil and cut filter. Very little trash in filter.
switched to 15w40 and a wix non bypass oil filter.
Cold idle pressure 75psi
Warm idle pressure 50psi
cruise pressure. 65psi
Slowing rolling into throttle to 5000 rpms will net 95 + psi
Now here is where the **** starts getting weird. If I'm in 2nd and floor it it'll climb to 75psi or so then drop lile a rock to mid to high 50s. As soon as i let out to shoots back up. Thought i was low on oil so i checked it. Dead on level....so i added a qt more and same results. Ebay fbody pan with the bypass blocked also.
Melling 10295 pump
New barbell.
DOD plugs and cover
Either the motor is in fact low on oil, the oil pump could be failing or not pumping oil sufficiently or the oil pressure sending unit is not working properly and may be producing a faulty reading.
Sounds like oil not returning to the pan fast enough, or simply too much windage from no tray, causing foaming. I'm betting on windage/foaming. Look into Milodon's Diamond Stripper windage tray/screen. It mounts to stepped down main studs. In the case of windage, more oil can work against you, and cause even more foaming. Hope this gives you something to consider.
The following users liked this post:
Jimbo1367 (04-18-2023)
I'm betting on foaming along with you. Also-To the OP; why in the world do you want 75psi oil pressure? It's bleeding more power than you think. Anything over 60psi in the LS engines is more problems than benefits, one of which you're probably seeing now. I also run the 10296. If I had to guess, you're also running the high pressure spring. Been too many years since I've read up on them, but I believe Melling supplies 2 different rate relief valve springs, one is installed, the other is extra. IIRC, the standard pressure spring comes installed. I'm guessing the high pressure spring is in the pump, either by personal choice, or Melling's choice......
Has there been a test of HP lose from oil pressure going from something like 60psi to 95psi? I've yet to see or read that other than internet here say.
Could running a truck windage tray instead of the fbody windage tray on a fbody pan cause this?
You are running out of oil in the PAN at high rpm, 15W40 DIESEL weight oil is "Stacking Up" top of the engine.
Try the same operation with 5W30, I'll bet the problem goes away.
15/40 is way too viscous for LS engines. Plus the diesel spec is wrong for gas engines.
If anybody thinks I'm wrong, summon Polyalphaolephin and ask him.
The following 3 users liked this post by G Atsma:
I'm really wondering if it has to do more with the truck windage tray rather than the fbody one.
You should try the 5w30 and see if that clears up your low pressure at high RPM. I ran into this issue with the 10296 pump and the fbody pan and windage tray but it had nothing to do with either of those it was insufficient pickup tube to pan clearance that caused my low oil pressure at high RPMs. 1/4 inch wasn't enough and it needed more like 3/8.
lazaris (09-20-2022)
I’m prolly on the tighter side of clearance, and my pickup is .235 from the pan floor. 10296 pump. Gibbs LS30 oil exclusively. Zero fluctuations on oil pressure regardless of rpm. I absolutely will not go over 3000 rpm until oil is at temp, which for my setup is 185-190.
99 Black Bird T/A (09-16-2022)
I ran 20w-50, 10296 pump, corvette pan and windage try. No issues with pressure fluctuations like you describe. Might have to do with the "ebay" version of your pan.
Dian (04-09-2023)
If suspect windage, run one quart low and see what happens. If the pressure drops less or more, it may help to give you a better idea. Obviously don’t hold it long or let it dip low if it drop further below what you already are seeing.
I would also try to replicate the pattern in neutral and then under driving load to try and help figuring it out.
Some good experience tips posted above though.
The following 4 users liked this post by FormulaBoat:
So why are you running a high volume pump with stock clearances? This has been known to cause issues and adding 15/40 further contradicts it. You're basically forcing thicker oil at a faster rate. I'd switch to 5/30 as the others said and test it. This high of pressure affects everything and is not always a benefit.
G Atsma (09-16-2022)
Im thinking of running a 5w20 or 5w30 on next oil change. I've read all the back and forth posts on diesel oil in gas engines. It just seams like a windage problem since the pressure jumps back up the instant I left off the gas.
I've been running the 10296 in the "batwing" C5 oil pan for years, and it's never cavitated. It's not exactly a deep sump, though there is a deep-er part that the pickup is in. One thing I'd like to say about the LS high volume pump. Pressure is pressure. What I mean is, bearing clearances will dictate what pressure the pump generates. You will get x amount of oil thru the bearings at 45psi. Let's say it's 5w-30. You won't get any more volume of oil thru the bearings at 45psi with a high volume vs a std pump. The pump can only flow so much oil past the bearings. The extra will be bled off by the relief spring Where a high volume pump comes into play is higher pressure at idle/lower rpm, looser bearing clearances, piston oil squirters, or quicker recovery of oil pressure if you've experienced high lateral g-forces. At 45psi, the high volume pump will put no extra oil thru the engine than a std pump, because the bearing clearances dictate a fixed number of gallons per minute at any given pressure. If you run a stiffer relief spring, then the high volume pump will be capable of flowing more oil, but so will the standard pump. I hope this makes sense, but somehow I don't think I've done a very good job of conveying what I'm trying to say. I will say this; I've spent many years at the strip, and had a lot of friends running hi volume pumps. I've never experienced, nor have any of my friends experienced, pumping the pan dry. I guess it's possible, at a sustained high rpm, with oil that's too thick, with an inadequate oil pan capacity, with a shimmed relief spring, with the pump cranking out 100psi. Still, nobody I know has ever had the sump run dry due to having a high volume pump.......
