RHS Billet Main Caps
Old Sep 30, 2022 | 11:25 AM
SteveJewels's Avatar
Veteran: Navy
Default RHS Billet Main Caps
Anyone using or know anything about RHS billet main caps?
Summit has them for 118.95
Old Sep 30, 2022 | 11:29 AM
OEM main caps are quite strong. Why would you need these?
Old Sep 30, 2022 | 01:47 PM
Veteran: Navy
I don't think there were caps on the block I bought so I might need to get caps anyway.
I'm not going to spend $500 on caps but a few extra bucks for billet steel I would if they are good. These were $118.95 at Summit
Old Sep 30, 2022 | 03:10 PM
DualQuadDave's Avatar
Those are just for RHS blocks, not GM LS blocks.
Old Sep 30, 2022 | 08:49 PM
Veteran: Navy
Thanks @DualQuadDave !
Old Sep 30, 2022 | 08:58 PM
The RHS caps at Summit, even if they would fit, will run you $594.75 before tax. Priced individually. You can get really nice Katech billet main caps direct from Katech for $524.99 before tax. I had a set of Katech caps fitted to my 434’s sleeved block and they are nice. They utilize a tool steel pin to help with cap walk. Justin Case your still looking…
Old Oct 2, 2022 | 02:38 PM
grinder11's Avatar
Can you use LS7 caps, or????
Old Oct 2, 2022 | 03:43 PM
No. LS7 and LS9 caps have different bolt spacing than other LS blocks. I wish they weren’t different. I can find them cheap all day long.
Old Oct 6, 2022 | 08:58 AM
grinder11's Avatar
Thanks for clarification. Thats something I did not know about these engines. LS7 is a bit different from others, for sure. Was surprised to learn the offset intake rockers on the LS7 arent offset the same as LS3. Guess I shoulda known!!
