Johnson 2116 or 2126?
If you were to pick between these two, which one would you pick and why would you pick them?
Discussions on short travel and/or slow leakdown welcome.
LS3, 427 CI, Ti CSC, Manley severe Flo Pro or Ferrera 6000 valves, Cam and springs TBD.
Please ask any pertinent questions.
Thanks!
Both the 2116 and the 2126 are available in short travel and non-short travel so that would not be a point on which to choose. Bischoff/BES is going to measure every one anyway and I have zero concerns about them making a mistake. The rockers are YT6667's and are not adjustable but that is not a concern for the same reason.
Titanium intake valves would be nice but may not be the best choice with a CSC. I am leaning toward robustness so hollow stems are probably not the choice there either.
Not sure you would need titanium intake valves if you are only spinning to 7,000.
There is more.....the less expensive 2116 linked above doesn't have the axle oiling feature. And its a "limited travel" lifter that has more travel than the more expensive short travel (.093 vs .058). Both are high quality.....short travels require more precise pushrod lengths and I normally recommend my clients check every cylinder with the short travel. FWIW, stock lifters can have plunger travel approaching .200, so .093 is alot less even in the limited travel option.
Axle oiling refers to the wheel actually getting pressurized oil to it from the lifter galley as opposed to having to rely on "splash oiling" from the crank which can be very little at idle and low RPM. It adds big time to the reliability factor.
PM me for more info, pricing, etc., and I can help guide you into which unit might be best for your application etc. assuming your in the market for lifters at the moment. The right lifter is worth serious power in an engine with more spring pressure, cam ramp intensity, and RPM and is often overlooked in budget and non budget builds for that matter.
-Tony
