Camshaft operating rpm
Old Oct 27, 2022 | 07:03 PM
Yoji h 123's Avatar
Default Camshaft operating rpm
So what if I camshaft that has an basic operating rpm of 3000 to 7400 is it possible to go higher than the basic operating rpm?
Old Oct 27, 2022 | 07:18 PM
99 Black Bird T/A's Avatar
Advancing or Retarding a Camshaft Summit is well worth checking and goes into details.
If the cam is retarded a few degrees normally it will make power higher. There are other factors like does the intake manifold help support the higher rpm range or work against it etc. Valve train has to support the higher rpm too etc.
jayyyw's Avatar
Yes, as long as your valvetrain is stable. Different intake manifolds will shift the peak rpm higher or lower depending on the length of the runners.
Depending on how well it holds power passed peak rpm, you might not want to rev it any higher.
Old Oct 27, 2022 | 08:08 PM
A cam's operating RPM is more about its intended powerband than physical limitations of the valvetrain.
Getting the valvetrain in shape for that range is up to the builder
Old Oct 28, 2022 | 10:46 AM
LilJayV10's Avatar
Camshaft and intake dictates the RPM range. Valvetrain determines if you can actually achieve it.
Old Oct 28, 2022 | 08:23 PM
FormulaBoat's Avatar
You can and it will, but it typically won’t make peak power past what is stated.
Are you trying to use a cam you already have outside of what it is rated for?
Old Nov 1, 2022 | 11:23 AM
Summitracing's Avatar
LS1Tech Sponsor
In general, as others have stated yes you can take a camshaft past its stated rpm range. You won't make more power necessarily but if you're trying to move out shift points or carry more rpm's into and through corners it can be of benefit. Just make sure your valvetrain and overall combo are up to the task of the rpm you're after. There are many factors that affect the operating range of a cam. Check out this article in our Help Center about camshaft operating range.
__________________
800-230-3030
www.SummitRacing.com
Old Nov 2, 2022 | 10:30 AM
grinder11's Avatar
Yes, agree. Also, OP: Do you know the LSA of the cam in question? Tighter LSA cams usually have the ability to carry power farther past peak, than (EDIT: meant WIDER!) wider LSA cams. This can be useful, as if you shift at 200-300 rpm past peak w/o dropping power (but realize you won't be making any additional power, either), it puts you that same 200-300 rpm higher in the next gear when shifted, which will help with 1/8 mile and 1/4 mile E.T. Hope this helps.......
Old Nov 2, 2022 | 12:02 PM
TIGHTER LSA cams usually have the ability to carry power farther past peak, than TIGHTER LSA cams.
You might want to edit this.....
Old Nov 2, 2022 | 06:54 PM
Yoji h 123's Avatar
yes, agree. Also, op: Do you know the lsa of the cam in question? Tighter lsa cams usually have the ability to carry power farther past peak, than tighter lsa cams. This can be useful, as if you shift at 200-300 rpm past peak w/o dropping power (but realize you won't be making any additional power, either), it puts you that same 200-300 rpm higher in the next gear when shifted, which will help with 1/8 mile and 1/4 mile e.t. Hope this helps.......
114 lsa
Old Nov 2, 2022 | 07:30 PM
What engine are you wanting to cam and what rpm do you want the power?
Old Nov 3, 2022 | 01:09 PM
grinder11's Avatar
How'd you guess Gary?!! Yup, fumble fingers......Or brain fart......Ill go with fumble fingers!!!
Old Nov 3, 2022 | 02:42 PM
Yoji h 123's Avatar
5.3 and 3000 to 7500+rpm's.
Old Nov 3, 2022 | 04:05 PM
WS6 Store High Lift 226/236 ASA cam in a 5.3 L33 pulls to 7,300 rpm is probably worth checking out if that's what you're wanting to do.
WS6 Store can help you pick parts and optimize for thst high rpm and probably more. Ideally you'll want an intake matched to support higher rpm.
